Microsoft Security Essentials - v4.2.223.1
Update April 13, 2014
I will no no longer be updating my add ons which are found throughout this forum. all files will eventually be deleted. Moving forward, I need my online storage for other projects. It was a pleasure to work with Win Toolkit. It is certainly a workhorse that i want in my Deployment Kit. Thanks everyone. I will continue to visit for as long as this project remains active. I really like the community here. PEACE OUT!
Microsoft Security Essentials x86/x64 v4.2.223 (Int'l)
Integrated: The latest virus definition version is: 1.145.381.0  |  Released: March 5, 2013 03:49 PM UTC
Integrated: Network Inspection System (NIS) version is: 17.36 / 18.36
About: This installer should work for ALL languages & architectures. Run this installer with /? or /h for detailed language mode (MUI) instructions. The default system language is used if not specified. Add these as silent installers. All switches are optional.
Download:
Link Removed
File: mseinstall_x86_x64_Intl_March_5_2013.exe (159.5 MB)
MD5: 9c5c27ca6c192b8bd09ecc5539295b1a
Config:
;!@Install@!UTF-8!GUIMode="2"GUIFlags="8"RunProgram="hidcon:setini.exe \"%%T\\%%P\\setup.ini\" Compat Market RunProgram="%%P\\setup.exe /s /runwgacheck /o"RunProgram="x86:mpam-fe.exe /q"RunProgram="x64:mpam-fe%%P.exe /q"RunProgram="x86:nis_full.exe /q"RunProgram="x64:nis_full%%P.exe /q";Thanks goes out to 'ricktendo' for his insight and guidance in helping me create this installer.;!@InstallEnd@!
Supported Languages:
bg-BG cs-CZ da-DKde-DEel-GRen-USes-ESet-EEfi-FIfr-FRhr-HRhu-HUit-ITja-JPko-KRlt-LTlv-LVnb-NOnl-NLpl-PLpt-BRpt-PTro-ROru-RUsk-SKsv-SEth-THtr-TRuk-UAvi-VNzh-CNzh-TW
Edited by dotfusion
  • Replies 62
  • Views 33.1k
What, no credit?
And you are doing it wrong, the updates (mpam-fe*.exe) installers you zipped will not get executed (even if you use /ai.) Leave mpam-fe*.exe outside the archive
BTW I was working on (but stopped) a true AIO MsSecEs istaller, one with ALL languages...You have to download ALL the installers to get the xx-XX sub folders with setup.dll.mui+EULA.RTF and edit setup.ini to remove Market=EN-US
This should now install correctly on any language Windows...
What, no credit?
Sorry, Updated with a note with credit info.
When you say leave mpam-fe*.exe outside the archive, do you mean outside the SFX or outside the x86 / x64 directory in the 7zip file. Can you elaborate please.
I'm also planning to continue your work with an all languages add-on / installer, that it if its okay with you. I presumed you had discontinued work on Security Essentials base on a post I saw in Installer Repack Requests
Edited by dotfusion
Yes, I mean outside next to your installer.
<your_installer>.exempam-fe.exempam-fex64.exe
If you look in the config.txt you will find %%S, this will translate to the path/folder your sfx is run from
%%M - SFX Archive Name Without Path
%%S - Full Path To The SFX Archive
%%T - The Full Path Extraction
Yes you may use my idea to make a All Lang In One installer (ALIO ;) ) you just need to remove that from setup.ini (I only tested it and confirmed it works on XP Spanish)
Edit: You may also want to update to 4.2, if you look at the setup.ini on this one it has removed the en-US and it already has all the xx-XX folders for all languages
x86: http://download.windowsupdate.com/msdownload/update/software/crup/2013/02/updateinstall_3ad554dd391f1d754ddd279e76cdc823d44244d8.exe
x64: http://download.windowsupdate.com/msdownload/update/software/crup/2013/02/updateinstall_ebd2cb6d79da21ae1fb45a192a460b132d788f77.exe
Thanks, Rick, I couldn't find any documentation on %S parameter for the 7zSD custom module, so i took a shot in the dark. I will post an update in the next day or so. Your insight would be much appreciated. Best Regards.
If you look in the config.txt you will find %%S, this will translate to the path/folder your sfx is run from.
Edited by dotfusion
@Rick,  MSSE 4.2 isn't final yet.  I can only find the pre-release.
The Pre-release is here: http://www.microsoft.com/en-us/download/details.aspx?id=29942
When you go to the official download pages you can only get 4.1
http://windows.microsoft.com/en-US/windows/security-essentials-download
http://www.microsoft.com/en-us/download/details.aspx?id=5201
But the pre-release version is 4.2.216.0 and the version you linked to is 4.2.223.0 but it appears to only be an update, not a full installer.
Weird!
I compared the MSI's and they both have the same amount of files, this indicates to me that its the FULL package not like a MSP with only the updated files and about it not being final, MU is offering it if you have 4.1 (at least it did for me)
Edit: dotfusion, you should use these links for MSE updates (the 64 bit has x64 in the filename, the installer needs this to distinguish)
x86: http://go.microsoft.com/fwlink/?LinkID=87342
x64: http://go.microsoft.com/fwlink/?LinkID=87341
Updated
- Integrated Definitions Update (Feb 21, 2013)
- Cleanup configuration file
- Cleanup 7z archive
Edited by dotfusion
Since you are making a package with the definitions as well you should think about adding NIS
http://www.wincert.net/forum/topic/11016-repak-microsoft-security-essentials-x86x64-v42223-intl/?p=95953
Feel free to use any config.txt code from my repack (you should at least grab all the languages and edit setup.ini to remove Market so you have a true AIO)
@ricktendo
Thanks for your insight on NIS, I will add it to the package today. As for the all languages in one (intl) I left them out because I felt adding it to my package would overlap with your repack. However, now that you mention it, if you don't mind, I'll do it. Thanks for your permission to adopt some of your config.txt
The only thing would be to remove the Market="EN-US" from setup.ini right? That would auto install the lang. native to that specific machine right?
Yep, remove that in setup.ini and it should automatically set your current language as the default one
You pack and mine are different, mine is not a wtk addon and with mine you need to provide the updates and make it silent (yours is for the toolkit advanced user, mine is more for the regular user but can also be used by advanced users)
Thanks rick, I use your more advance pack on a build I use for corp. installs. i find it quite flexible. But i also like the simplicity of mine, exactly for the reasons you said ... Thanks again for your insight.
Edited by dotfusion
Updated
- Integrated Virus Definitions (Feb 23, 2013)
- Added all available languages (int'l) :)
- Cleaned up  configuration file
Edited by dotfusion
Updated...
Integrated: The latest virus definition version is: 1.145.381.0 | Released: Feb 23, 2013 09:51 PM UTC
Updated...now you can force the installation language
<installer>.exe xx-XX and/or <installer>.exe /ai xx-XX
Thanks to McRip for the SetIni suggestion, it was tough figuring out how to do this but turns out the solution was very simple
Edited by dotfusion
Thanks for the good work. Now to my problem.
I want to install this silent but it is not. Have tried / ai sv-SE as a switch does not work.
Any tips for me. Thanks in advance
Edited by Sven
When I try to install with / ai sv-SE, I get error Could not find command for "AutoInstall"
Same at / ai
Installation without switching see Picture
Windows 7 ultimate 64-bit Swedish
Edited by Sven
Thanks Sven, ricktendo, and myselfidem for pointing out the missing setini. I'll fix it tonite and reupload.
Edited by dotfusion
