Posted February 19, 201312 yr Homepage MP3 Quality Modifier is a straightforward program that is able to easily change the quality of your MP3's in order to save disk space and/or to fit more music on your MP3 player while maintaining the desired level of audio quality and keeping all ID3 tags intact!The program is pretty simple to use: The first step is to drag and drop MP3 files or playlists on the file list, MP1 and MP2 files are supported as well. Various information such as the name, interpret, size and bitrate are displayed automatically.The next step is to select a preset which ranges from high quality over portable and compromise to low quality. More advanced users can choose from a variety of configurations such as bitrate mode and rate, sample frequency and the stereo modus.The process itself takes only a few seconds per song and is even able to adapt the folder structure (example: “Artist X” folder with “Album 1” and “Album 2” as subfolders) if that is wanted. Unlike other tools all ID3 tags like the title, artist etc. are automatically retained as well.Finally the result window allows to compare the original and created music files by listing their size differences.Main Features: Easy & intuitive: Change quality and size of your MP3 files with just a few mouse-clicks Support for M3U and PLS playlist files Automatically keep all ID3 tags and the folder structure Advanced options: Detailed bitrate settings, mark as copyrighted etc. Quick quality comparison between original and created files Multilingual: DE, EN, ES, ET, FR, IT, KO, NL, PT, RU, SR, SV, TR Portable: Just one executable, no need for installation MP3QualityModifier251.WASize: 679.95 Kb (696,271 bytes)MD5: 1F86FDB55881A4E219B9AA4E9958ECB3Should be able to run on x64 but not tested. Only tested on x86.If it works on x64, please let other knows...
