Auslogics Registry Defrag
Description
An essential tool for keeping your registry defragmented.
It will improve your computer performance by reducing the
amount of memory your registry takes up.
Eliminates structural defects in the registry
Reduces the amount of RAM the registry takes up
Improves applications response time
Makes Windows running more stable
Improves overall computer performance
6.5.1.0 (19/01/2013)fixed several bugscorrected errors in language files
Version: 6.5.1.0
Platform: x86 & x64
Addon Release Date: February 20, 2013
Uninstallable: Yes
Credit: *Reaper*
NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.
Must use Win Toolkit 1.4.1.14 or higher!
size.jpg4.71 MB
md5.jpg2fd080fd4653fb41522690ee771cb0df
Enjoy!
  • 6 months later...
