Posted February 21, 201312 yr Microsoft Security Essentials x86/x64 v4.5.216 (ALL languages in ONE)About: This installer should work for ALL languages & architectures. Run this installer with /? or /h for detailed silent install instructions (the default is not silent and no updates are installed)Supported OS(s): Windows XP Service Pack 3 (SP3)*; Windows Vista (Service Pack 1, or Service Pack 2)*; Windows 7*Download: http://adf.ly/1713566/mssecesaioMD5: 2571d79679ae8b8f72784633e01eb65aSize: 14.4 MB Definition Updatesx86: http://go.microsoft.com/fwlink/?LinkID=87342x64: http://go.microsoft.com/fwlink/?LinkID=87341 Supported Languages:bg-BGcs-CZda-DKde-DEel-GRen-USes-ESet-EEfi-FIfr-FRhr-HRhu-HUit-ITja-JPko-KRlt-LTlv-LVnb-NOnl-NLpl-PLpt-BRpt-PTro-ROru-RUsk-SKsr-Latn-CSsv-SEth-THtr-TRuk-UAvi-VNzh-CNzh-TW
February 21, 201312 yr Rick, is the language selected automatically? For example if my system was English and I want MSE in German, it would obviously install the English version, right. If that would be true, could you make it possible to make a switch for selecting one's own language? Edited February 21, 201312 yr by McRip
February 21, 201312 yr Author Yes, it will install using your current system lang I tried adding Market=xx-XX in the hopes I could force the installer to choose a different language but that did not work...next will try editing setup.ini that should do the trick, but I have to figure out a clever way to implement it
February 21, 201312 yr That would be awesome. Thanks a lot for your efforts. I'm a wait for your next version.
February 21, 201312 yr Question; can your package also add the nis_full.exe file as well?FYI I use the following to quickly update my existing method and will now use it for yourswget64.exe go.microsoft.com/fwlink/?LinkID=121721&arch=x64wget64.exe go.microsoft.com/fwlink/?linkid=207870wget64.exe download.microsoft.com/download/DefinitionUpdates/mpam-fex64.exe
February 21, 201312 yr There is an x86 and x64 version: http://www.microsoft.com/security/portal/definitions/howtomse.aspx Network Inspection System definitions:http://go.microsoft.com/fwlink/?LinkID=187316&arch=x86http://go.microsoft.com/fwlink/?LinkID=187316&arch=x64
February 21, 201312 yr Author Do you know of a fwlink from Microsoft that will download a file with x64 in the name (nis_fullx64.exe) same as the definitions? I need this difference between the two filenames so that the installer will call the right one depending on what arch it detects you are launching from Updated...now you can force the installation language<installer>.exe xx-XX and/or <installer>.exe /ai xx-XXThanks to McRip for the SetIni suggestion, it was tough figuring out how to do this but turns out the solution was very simple
February 21, 201312 yr There is an x86 and x64 version: http://www.microsoft.com/security/portal/definitions/howtomse.aspx Network Inspection System definitions:http://go.microsoft.com/fwlink/?LinkID=187316&arch=x86http://go.microsoft.com/fwlink/?LinkID=187316&arch=x64You don't need the network inspection system definitions. Those won't get installed on a Win 7 system. Trust me...
February 21, 201312 yr Author You don't need the network inspection system definitions. Those won't get installed on a Win 7 system. Trust me...I think you mean they dont install on XP
February 22, 201312 yr I have never been able to find one with the x64 designation and I used to just rename mine with my scriptDo you know of a fwlink from Microsoft that will download a file with x64 in the name (nis_fullx64.exe) same as the definitions?I need this difference between the two filenames so that the installer will call the right one depending on what arch it detects you are launching from
February 22, 201312 yr @compstuff, OT - Where did you get wGet64? What version is it? When I have used wGet, I have used Wget v1.11.4, along with wGetGUI v1.20, both of which were the latest versions I was aware of. Cheers and Regards Edited February 22, 201312 yr by bphlpt
February 22, 201312 yr Author I think I will leave that one out for the time being, because its not compatible with XP and the x64 in the filename.If you think you can do it you could rebuild the sfx with the capabilities...just add this to the config.txtAutoInstall="x86:\"%%S\\nis_full\" /q"AutoInstall="x64:\"%%S\\nis_full%%P\" /q"Let me know if you need helpEdit: BTW reuploaded, does not affect install only minor help dialog improvements
February 22, 201312 yr Sorry for asking, but: What is the purpose of nis.exe?How can I see the build of MSE? From compstuff's link: If you are running Microsoft Security Essentials build 2.0.0375.0 or higher, you also need to download the following Network Inspection System definitions This is my installed MSE Regards, Thiersee
February 22, 201312 yr http://www.alexlomas.com/blog/2005/08/64_bit_wget_for_windows/@compstuff, OT - Where did you get wGet64? What version is it? When I have used wGet, I have used Wget v1.11.4, along with wGetGUI v1.20, both of which were the latest versions I was aware of. Cheers and Regards
February 22, 201312 yr This explains it better than I can :-)http://www.windowsecurity.com/articles-tutorials/intrusion_detection/Network-Inspection-System-Enhances-Security-Microsoft-Security-Essentials-TMG-Firewall.htmlSorry for asking, but: What is the purpose of nis.exe?How can I see the build of MSE? From compstuff's link: This is my installed MSE Regards, Thiersee Edited February 22, 201312 yr by compstuff
February 22, 201312 yr Since I am not on XP I could be wrong... but I think they do actually get installed its just that XP doesn't have the capable service to make use of them and it never will You don't need the network inspection system definitions. Those won't get installed on a Win 7 system. Trust me... I think I will leave that one out for the time being, because its not compatible with XP and the x64 in the filename. Edited February 22, 201312 yr by compstuff
February 22, 201312 yr I will PM you :dizzy: If you think you can do it you could rebuild the sfx with the capabilities...just add this to the config.txtAutoInstall="x86:\"%%S\\nis_full\" /q"AutoInstall="x64:\"%%S\\nis_full%%P\" /q"Let me know if you need help
February 22, 201312 yr http://www.alexlomas.com/blog/2005/08/64_bit_wget_for_windows/Thanks, I thought so but thought I'd make sure. I wonder if it would also be compatible with wGetGUI v1.20? I'll have to try it and see one of these days. Cheers and Regards
February 22, 201312 yr I never knew about the GUI so you turned me on to that one... thanks :-)Thanks, I thought so but thought I'd make sure. I wonder if it would also be compatible with wGetGUI v1.20? I'll have to try it and see one of these days.Cheers and Regards Edited February 22, 201312 yr by compstuff
July 25, 201311 yr Microsoft Security Essentials 4.3.216.0 is out !Nice link. :doh:Here you go. http://www.microsoft.com/en-us/download/details.aspx?id=5201Updates: http://www.microsoft.com/security/portal/definitions/adl.aspx Edited July 25, 201311 yr by Mr_Smartepants
