Posted February 22, 201312 yr Hi, i have problems with two programs i like to install.It's Act 13 from Sage Software and Microsoft Navision. It seems both of them have problems because there are pending reboots for the system. Also if i delete the pending reboot keys in the registry, for example Act 13 tries forced install somethinggoes wrong with the sql express... so i need a reboot on half way. Is it possible that the installer goes on with the rest missing? Greetz X23 Edited March 11, 201312 yr by x23piracy
February 22, 201312 yr Possible, use setupcomplete.cmd Here is mine: @echo on:: Set Pagefile Size to 1024MB fixed Sizewmic computersystem where name="%computername%" set AutomaticManagedPagefile=Falsewmic pagefileset where name="C:\\pagefile.sys" set InitialSize=1024,MaximumSize=1024:: Disable Hibernationpowercfg -h off:: Set Network Interfaces MTUnetsh interface ipv4 set subinterface "Wireless Network Connection" mtu=1430 store=persistentnetsh interface ipv4 set subinterface "Local Area Connection" mtu=9014 store=persistent:: Delete Sensitive Setup Informationdel /Q /F "%WinDir%\system32\sysprep\unattend.xml"del /Q /F "%WinDir%\panther\unattend.xml":: Disable RacTask To Get Sleep Working on Overclocked Z68 Boardschtasks.exe /change /tn \Microsoft\Windows\RAC\RacTask /disable:: Fix Windows WMI Event ID:10 Errorcscript %WinDir%\Setup\Scripts\WMI-Error-ID10-Fix.vbs:: Reboot Computer to finish%WinDir%\system32\shutdown.exe -r -f -t 0 It reboots machine, before WinToolkit Installer has started...feel free to customize...
February 22, 201312 yr Author Hi, thank you for the reply but i need a reboot somewhere in the middle of the installer process not before or after lets say i have 20 manuals install and i need reboot after install number 11 then it should go on for 12-20 after the reboot... Greetz X23 Edited February 22, 201312 yr by x23piracy
February 23, 201312 yr I'm not clear. Do the installs cause the requirement for a reboot themselves, or will they not install correctly because something else caused the need for a reboot? In either case, you could try to change your install order so that the one that causes the need for a reboot is done last. Cheers and Regards
February 24, 201312 yr Author Hi, I'm not clear. Do the installs cause the requirement for a reboot themselves, or will they not install correctly because something else caused the need for a reboot? In either case, you could try to change your install order so that the one that causes the need for a reboot is done last.Cheers and Regards iam sure its not navision or act 13 itself causing the reboot issue must be a program before that produces this pending reboot, yeah i can change the order but first i have to locate which setup is causing the pending reboot. Another thing i mentioned. i have a fresh image with integrated all gdr updates some of them over sfx, when installer appears for my manual setup i allready see the standard windows message that the system need a reboot (now, or no i do it later) maybe this is the problem, something related with installling all the updates (integration). These are the updates i integrate: IE9-Windows6.1-KB2792100-x64.msuIE9-Windows6.1-KB2797052-x64.msuIE9-Windows6.1-KB982861-x64.msuWindows6.1-KB2476490-x64.msuWindows6.1-KB2479943-x64.msuWindows6.1-KB2487335-x64.msuWindows6.1-KB2488113-x64.msuWindows6.1-KB2491683-x64.msuWindows6.1-KB2496898-v3-x64.msuWindows6.1-KB2503658-x64.msuWindows6.1-KB2505438-x64.msuWindows6.1-KB2506014-x64.msuWindows6.1-KB2506212-x64.msuWindows6.1-KB2506628-x64.msuWindows6.1-KB2506928-v2-x64.msuWindows6.1-KB2509553-x64.msuWindows6.1-KB2511250-x64.msuWindows6.1-KB2511455-x64.msuWindows6.1-KB2515325-x64.msuWindows6.1-KB2522422-x64.msuWindows6.1-KB2524375-x64.msuWindows6.1-KB2525694-x64.msuWindows6.1-KB2529073-x64.msuWindows6.1-KB2534366-x64.msuWindows6.1-KB2536275-x64.msuWindows6.1-KB2536276-v2-x64.msuWindows6.1-KB2541014-x64.msuWindows6.1-KB2544893-x64.msuWindows6.1-KB2545698-x64.msuWindows6.1-KB2547666-x64.msuWindows6.1-KB2552343-x64.msuWindows6.1-KB2556532-x64.msuWindows6.1-KB2560656-x64.msuWindows6.1-KB2563227-x64.msuWindows6.1-KB2564958-x64.msuWindows6.1-KB2570947-x64.msuWindows6.1-KB2579686-x64.msuWindows6.1-KB2584146-x64.msuWindows6.1-KB2585542-x64.msuWindows6.1-KB2604115-x64.msuWindows6.1-KB2604521-v2-x64.msuWindows6.1-KB2607576-x64.msuWindows6.1-KB2618301-x64.msuWindows6.1-KB2618451-x64.msuWindows6.1-KB2619339-x64.msuWindows6.1-KB2620704-x64.msuWindows6.1-KB2620712-x64.msuWindows6.1-KB2621440-x64.msuWindows6.1-KB2624668-x64.msuWindows6.1-KB2631813-x64.msuWindows6.1-KB2639308-x64.msuWindows6.1-KB2640148-v2-x64.msuWindows6.1-KB2640696-v3-x64.msuWindows6.1-KB2641690-x64.msuWindows6.1-KB2644615-x64.msuWindows6.1-KB2645640-x64.msuWindows6.1-KB2647753-v4-x64.msuWindows6.1-KB2653956-x64.msuWindows6.1-KB2654428-x64.msuWindows6.1-KB2655992-x64.msuWindows6.1-KB2656356-x64.msuWindows6.1-KB2656411-x64.msuWindows6.1-KB2657025-x64.msuWindows6.1-KB2658846-x64.msuWindows6.1-KB2659262-x64.msuWindows6.1-KB2660075-x64.msuWindows6.1-KB2660649-x64.msuWindows6.1-KB2661254-x64.msuWindows6.1-KB2667402-v2-x64.msuWindows6.1-KB2676562-x64.msuWindows6.1-KB2677070-x64.msuWindows6.1-KB2679255-v2-x64.msuWindows6.1-KB2685811-x64.msuWindows6.1-KB2685813-x64.msuWindows6.1-KB2685939-x64.msuWindows6.1-KB2690533-x64.msuWindows6.1-KB2691442-x64.msuWindows6.1-KB2698365-x64.msuWindows6.1-KB2699779-v2-x64.msuWindows6.1-KB2705219-v2-x64.msuWindows6.1-KB2709630--x64.msuWindows6.1-KB2709981-v2-x64.msuWindows6.1-KB2712808-x64.msuWindows6.1-KB2718704-x64.msuWindows6.1-KB2719857-x64.msuWindows6.1-KB2719985-x64.msuWindows6.1-KB2726535-x64.msuWindows6.1-KB2727528-x64.msuWindows6.1-KB2729094-v2-x64.msuWindows6.1-KB2729452-x64.msuWindows6.1-KB2732059-v5-x64.msuWindows6.1-KB2732487-v2-x64.msuWindows6.1-KB2732500-v2-x64.msuWindows6.1-KB2735855-x64.msuWindows6.1-KB2736233-x64.msuWindows6.1-KB2736422-x64.msuWindows6.1-KB2739159-x64.msuWindows6.1-KB2741355-x64.msuWindows6.1-KB2742599-x64.msuWindows6.1-KB2743555-x64.msuWindows6.1-KB2749655-x64.msuWindows6.1-KB2750841-x64.msuWindows6.1-KB2753842-v2-x64.msuWindows6.1-KB2756921-x64.msuWindows6.1-KB2757638-x64.msuWindows6.1-KB2758857-x64.msuWindows6.1-KB2760730-v2-x64.msuWindows6.1-KB2761217-x64.msuWindows6.1-KB2762895-x64.msuWindows6.1-KB2763523-x64.msuWindows6.1-KB2769369-x64.msuWindows6.1-KB2770660-x64.msuWindows6.1-KB2773072-x64.msuWindows6.1-KB2778344-x64.msuWindows6.1-KB2785220-x64.msuWindows6.1-KB2786081-x64.msuWindows6.1-KB2786400-x64.msuWindows6.1-KB2789645-x64.msuWindows6.1-KB2790113-x64.msuWindows6.1-KB2790655-x64.msuWindows6.1-KB2794119-x64.msuWindows6.1-KB2799494-x64.msuWindows6.1-KB917607-x64.msuWindows6.1-KB982018-v3-x64.msuWUClient-SelfUpdate-ActiveX-x64.cabWUClient-SelfUpdate-Aux-TopLevel-x64.cabWUClient-SelfUpdate-Core-TopLevel-x64.cab These are my SFX: IE9-Windows6.1-LanguagePack-x64-deu.msumpas-feX64.exeNDP45-KB2789648-x64.exeReapers.Dot.Net.Framework.4.5.AIO.x64.exeReapers.Microsoft.Malicious.Software.Removal.4.17.x64.exervkroots.exeSilverlight-x64.exetouch-pack-web.exeVBCFJRedist_AIO_x86_x64.exeWindows6.1-KB2533552-x64.msuWindows6.1-KB2603229-x64.msuWindows6.1-KB958559-x64-RefreshPkg.msuWindowsXPMode_de-de.exe After this i have a fully patched system (todays date 24th feb 2013) but with installer appears i see the standard windows message to reboot (yes/no (later)) maybe this is my problem... if not something that is installed before navision or act 13... hmmm The only thing windows update offers is the browser choice kb (i dont want it). Maybe i should try setupcomplete.cmd to trigger a reboot before installer appears, i hope the installer will appear after a forced reboot with setupcomplete.cmd? Greetz X23 Edited February 24, 201312 yr by x23piracy
February 24, 201312 yr Author Hi, i hope the installer will appear after a forced reboot with setupcomplete.cmd? yes it does! Fascinating it works a forced reboot with setupcomplete.cmd and after the reboot installer appear normally, only thing iam wondering is that background color is black now (black is beauty)... My setupcomplete.cmd: @echo offrem START %systemdrive%\D\SAD2\DP_Install_Tool.cmd /sshutdown -r -t 0 -f Now i have to test my installers in the old order to see if this reboot is the goal or if another installer is causing the pending reboot and denying navision and act 13 to install... but not yet i have to sleep now... later ladys EDIT: It seems that after the forced reboot the windows theme aero is applied to the system windows look like that, i just don't understand the black background (it's just cosmetic and no real problem). EDIT2: after the forced reboot and waiting for finishing installer doing its work i immediatelly triggered windows update, it doesnt say immediatelly you need to reboot to search for updates now it seems to really checking whats installed (needs more time) but in the end it also tells me to reboot before it can install updates if available... After the reboot i directly started windows update again, know it doesnt need to search again it tells me immediatelly that i can install kb976002 if i want (browser choice)... the update i dont want so ok everything fine, but after the forced reboot with setupcomplete there is something else at least related to windows update... this must be nothing related to my navision or act 13 problem but it feels a bit strange... Now iam really falling asleep Greetz X23 Edited February 24, 201312 yr by x23piracy
February 24, 201312 yr IE9-Windows6.1-LanguagePack-x64-deu.msumpas-feX64.exeNDP45-KB2789648-x64.exeReapers.Dot.Net.Framework.4.5.AIO.x64.exeReapers.Microsoft.Malicious.Software.Removal.4.17.x64.exervkroots.exeSilverlight-x64.exetouch-pack-web.exeVBCFJRedist_AIO_x86_x64.exeWindows6.1-KB2533552-x64.msuWindows6.1-KB2603229-x64.msuWindows6.1-KB958559-x64-RefreshPkg.msuWindowsXPMode_de-de.exe Sorry for asking, but: does it work in this sequence???NDP45-KB2789648-x64.exe before Reapers.Dot.Net.Framework.4.5.AIO.x64.exeWindows6.1-KB958559-x64-RefreshPkg.msu before WindowsXPMode_de-de.exe BTW:Reapers.AIO contains already NDP45-KB2789648-x64.exeyou can install also as update:WindowsXPMode_de-de.exeIE9-Windows6.1-LanguagePack-x64-deu.msu Thiersee
February 24, 201312 yr Author Hi, Sorry for asking, but: does it work in this sequence???NDP45-KB2789648-x64.exe before Reapers.Dot.Net.Framework.4.5.AIO.x64.exeWindows6.1-KB958559-x64-RefreshPkg.msu before WindowsXPMode_de-de.exe BTW:Reapers.AIO contains already NDP45-KB2789648-x64.exeyou can install also as update:WindowsXPMode_de-de.exeIE9-Windows6.1-LanguagePack-x64-deu.msu Thiersee yes the sequence works like that. Installing IE Lang upd via update does not work, will be integrated but ie is not german then stays on english so something with the integration process is wrong and i switched to install as sfx. Which sequence would you prefer? I know that Windows XP Mode works as update but at this time i dont want to integrate more then additional 500mb, so actually i stay with it as manuall install but thanks for the info. I have an older Reaper AIO it seems he integrated NDP45-KB2789648-x64.exe since last time i downloaded the pakage. EDIT: Argh i got you wrong, my list is not the sequence i use that is just a dir /b >file.txt My Sequence is: Greetz X23 Edited February 24, 201312 yr by x23piracy
February 24, 201312 yr I know that Windows XP Mode works as update but at this time i dont want to integrate more then additional 500mb, so actually i stay with it as manuall install but thanks for the info.Ok, this is a good reason ! Installing IE Lang upd via update does not work,will be integrated but ie is not german then stays on english sosomething with the integration process is wrong and i switched toinstall as sfx. Which sequence would you prefer?I have just installed a new integration and IE9 is in german http://www.pic-upload.de/view-18270466/IE9-DE.jpg.html The .INI I used for this integration is *AIO#AddonsE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers_Arcade_Classic_Pack_5.10_x64_Windows7_AddOn.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers_Microsoft_3D_Pinball_5.1.2600.5512_x64_Windows7_AddOn.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers_Prime95_26.6.1.0_x64_Windows7_AddOn.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers.Speccy.1.20.446.x64.Windows7.or.8.Control.Panel.AddOn - Thiersee.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers.Cpu.Z.1.63.0.x64.Windows7.or.8.Control.Panel.AddOn.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers.Win.Toolkit.1.4.1.14.x64.Windows7.or.8.AddOn.WAE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Reapers\Reapers.Hodoku.2.1.3.x64.Windows7.or.8.AddOn.WA#ComponentsInbox GamesInternet GamesMobile PC Client Components (Basic)Mobile PC Client Components (Premium)Premium Inbox GamesTablet PC Components#DriversE:\DriverWin7\2333W-Inf\EV2333W.infE:\DriverWin7\Display_entpackt_12.6_legacy\W76A_INF\C7145534.infE:\DriverWin7\Display_entpackt_12.6_legacy\W76A_INF\CH145534.infE:\DriverWin7\Motherboard\Renesas_3.0_2.1.39.0\oem5.infE:\DriverWin7\Motherboard\Renesas_3.0_2.1.39.0\oem6.infE:\DriverWin7\Driver_Win7_7067_01222013\WIN7\64\rt64win7.infE:\DriverWin7\Motherboard\AHCI_win7\W764A\amd_sata.infE:\DriverWin7\Drivers Backup\Prolific USB-to-Serial Comm Port\oem30.inf#FilesBugle-call.wav::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Bugle-call.wav;%SystemDrive%\Windows\Media\Bugle-call.wav;TrueElster.ico::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Elster.ico;%SystemDrive%\Windows\Icons\Elster.ico;TrueKukuck.wav::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Kukuck.wav;%SystemDrive%\Windows\Media\Kukuck.wav;TrueMagix.ico::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Magix.ico;%SystemDrive%\Windows\Icons\Magix.ico;Truemfc100u.dll::E:\DriverWin7\mfc100u.dll;%SystemDrive%\Windows\System32\mfc100u.dll;Truemsvcp100.dll::E:\DriverWin7\msvcp100.dll;%SystemDrive%\Windows\System32\msvcp100.dll;Truemsvcr100.dll::E:\DriverWin7\msvcr100.dll;%SystemDrive%\Windows\System32\msvcr100.dll;Truenero.ico::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\nero.ico;%SystemDrive%\Windows\Icons\nero.ico;TrueOEMInformation.reg::E:\ServicePacks-Install\Win_7\$OEM$\$$\Setup\Scripts\OEMInformation.reg;%SystemDrive%\Windows\Setup\Scripts\OEMInformation.reg;TrueOEMLOGO.bmp::E:\ServicePacks-Install\Win_7\$OEM$\$$\System32\OEMLOGO.bmp;%SystemDrive%\Windows\System32\OEMLOGO.bmp;Trueoobe.cmd::E:\ServicePacks-Install\Win_7\$OEM$\$$\Setup\Scripts\oobe.cmd;%SystemDrive%\Windows\Setup\Scripts\oobe.cmd;TrueProfilbild.JPG::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Profilbild.JPG;%SystemDrive%\Windows\Icons\Profilbild.JPG;TrueS65-Kukuck.wav::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\S65-Kukuck.wav;%SystemDrive%\Windows\Media\S65-Kukuck.wav;TrueToilet.wav::E:\ServicePacks-Install\Win_7\Extra-Win7\Icon-Sound\Toilet.wav;%SystemDrive%\Windows\Media\Toilet.wav;TrueW7_ptbtime_gesamt.reg::E:\ServicePacks-Install\Win_7\$OEM$\$$\Setup\Scripts\W7_ptbtime_gesamt.reg;%SystemDrive%\Windows\Setup\Scripts\W7_ptbtime_gesamt.reg;True#GadgetsE:\ServicePacks-Install\Win_7\Windows_Gadget\Austria.gadgetE:\ServicePacks-Install\Win_7\Windows_Gadget\Firefox.Clock.DE.GadgetE:\ServicePacks-Install\Win_7\Windows_Gadget\Italy.gadgetE:\ServicePacks-Install\Win_7\Windows_Gadget\shutdown_v2.gadgetE:\ServicePacks-Install\Win_7\Windows_Gadget\steuerung.gadgetE:\ServicePacks-Install\Win_7\Windows_Gadget\World_Clock.gadget#ServicesDisk Defragmenter::DisabledProgram Compatibility Assistant::DisabledSuperfetch::DisabledWindows Update::Disabled#Silent InstallsCAPICOM-KB931906-v2102::/Q;NO;374.39 KB;E:\ServicePacks-Install\Win_7\Updates-Maerz\CAPICOM-KB931906-v2102.exe;Always Installedmsxml_4_SP3::/passive /norestart;NO;2.25 MB;E:\ServicePacks-Install\Win_7\Updates-Maerz\msxml_4_SP3.msi;Always Installedmsxml4-KB2758694-deu::/passive /norestart;NO;1.98 MB;E:\ServicePacks-Install\Win_7\Updates-Maerz\msxml4-KB2758694-deu.exe;Always Installeddotnetfx45_full_x86_x64::/lcid 1031 /passive /norestart;NO;48.02 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\McRip\dotnetfx45_full_x86_x64.exe;Always Installeddotnetfx45lp_full_x86_x64de::/passive /norestart;NO;4.09 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\McRip\dotnetfx45lp_full_x86_x64de.exe;Always InstalledNET45UPPRESP1-x64::;NO;108.25 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\McRip\NET45UPPRESP1-x64.exe;Always InstalledMcRipSFbeta3-2.0.0::/VERYSILENT /NORESTART;NO;232.80 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\McRip\SF\McRipSFbeta3-2.0.0.exe;Always InstalledVC_RedistInstaller_1.5.1::/VERYSILENT /NORESTART;NO;40.56 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\McRip\VC\VC_RedistInstaller_1.5.1.exe;Always InstalledClassicShellSetup_3.6.5::;NO;6.03 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Thiersee\ClassicShellSetup_3.6.5_silent.exe;Always Installed7-Zip_9.20_x64::;NO;1.40 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Unantastbar\7-Zip_9.20_x64.exe;Always InstalledFirefox_Setup_19.0::;NO;19.84 MB;E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\Thiersee\Firefox_Setup_19.0_silent.exe;Always InstalledMSEInstall_x64_de_de_4.2.0233::/s /runwgacheck;NO;12.88 MB;E:\TeX-Virenscan\Virenscanner\MSEInstall_x64_de_de_4.2.0233.exe;Always InstalledMSSecurityEssential_Virendefinition_x64_mpam-fe::/q;NO;70.33 MB;E:\TeX-Virenscan\Virenscanner\MSSecurityEssential_Virendefinition_x64_mpam-fe.exe;Always InstalledKB2603229::N/A (Not Needed);NO;193.42 KB;E:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2603229-x64.msu;Always InstalledKB2533552::N/A (Not Needed);NO;9.23 MB;E:\ServicePacks-Install\Win_7\Updates-Maerz\Windows6.1-KB2533552-x64.msu;Always InstalledKB2592687::N/A (Not Needed);NO;6.80 MB;E:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2592687-x64.msu;Always InstalledWindows Virtual PC (KB958559)::N/A (Not Needed);NO;16.30 MB;E:\ServicePacks-Install\Win_7\XP-Mode\Windows6.1-KB958559-x64-RefreshPkg.msu;Always InstalledKB2652034::N/A (Not Needed);NO;344.30 KB;E:\ServicePacks-Install\Win_7\XP-Mode\Windows6.1-KB2652034-v2-x64.msu;Always InstalledKB2697737::N/A (Not Needed);NO;1.70 MB;E:\ServicePacks-Install\Win_7\XP-Mode\Windows6.1-KB2697737-x64.msu;Always InstalledAdbeRdr11002_de_DE::/sPB /rs;NO;48.46 MB;E:\Allgemein CD3\Adobe-PDF\AdbeRdr11002_de_DE.exe;Always InstalledKB2506143::N/A (Not Needed);NO;15.79 MB;E:\ServicePacks-Install\Win_7\Updates-Maerz\Windows6.1-KB2506143-x64.msu;Always Installed#Theme Packs|E:\ServicePacks-Install\Win_7\Windows_Theme\SienaArchitettura.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Antarctic.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Arctic.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\austria1.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\austria2.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\BlueWater.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Brazil.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Canada.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\CastlesOfEurope.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\CatsAnytime.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\CatsEverywhere.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\DogsInSummer.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\DuskDawn.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\GalapagosByRG.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Italy.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\JoshSommersBeaches.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\SnowSports.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Surfing.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Surfing_1.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Tigers.themepackE:\ServicePacks-Install\Win_7\Windows_Theme\Winter.themepack#TweaksAdd 'Copy To Folder' to context-menuAdd 'Open CMD here' to Folder Context-menuAdd 'Open Elevated CMD here' to Folder context-menuLarger Taskbar PreviewsShow 'Computer' on DesktopShow 'Control Panel' on DesktopShow 'Network' on DesktopUnlock the taskbarAllow 3rd Party ThemesAlways Show Menu BarsChange Default Background::E:\ServicePacks-Install\Win_7\Windows_Wallpapers\architettura_siena-piazza-del-campo2.jpgRemove Shortcut SuffixShow All Icons on System TrayShow Drive Letters FirstShow Explorer StatusbarShow File ExtensionsShow Hidden Files & FoldersShow System FilesEnable DVD in Media PlayerShow Notepad StatusbarAlways Show Menu BarDisable Password Caching in Internet ExplorerIE Homepage::www.google.atLaunch Internet Explorer in Separate ProcessShow IE StatusbarUnlimited Simultaneous DownloadsChange Logon Background::E:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Kopie_von_100_0045_0001_NEW.jpgDisable User Account ControlRestore Previous Folder at LogonDisable Dr WatsonDisable HibernationDisable PrefetchDisable SuperfetchImprove USB Storage Devices Performance#UpdatesE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\IE9-Windows6.1-LanguagePack-x64-deu.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Windows6.1-KB2425227-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2479943-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2484033-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2487426-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2488113-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2505438-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2491683-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2496898-v3-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2506014-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2506212-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2753842-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2509553-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2511250-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2511455-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2522422-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2524375-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2487335-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2762895-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2506628-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2506928-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2515325-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2529073-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB982018-v3-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2525694-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2536275-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2541014-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2544893-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2548388-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2532531-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2533623-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2545698-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2547666-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2552343-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2536276-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2546868-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2560656-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2562937-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2563227-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2758857-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2570947-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2607712-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2616676-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2564958-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2579686-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2578214-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2598845-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2604521-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2607576-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2618301-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2619572-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2620704-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2618451-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2619339-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2620712-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2633952-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2641690-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2584146-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2585542-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2631813-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2632503-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2644615-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2624668-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2640148-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2640696-v3-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2645640-x64.msuE:\ServicePacks-Install\Win_7\Windows_7_Toolkit\IE9-Windows7-x64-deu.exeE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2654428-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2657025-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2660075-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB971033-x64.MSUE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2621440-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2639308-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2647518-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2653956-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2679255-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2658846-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2659262-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2660649-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2676562-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2690533-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2695962-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2667402-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2677070-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2685939-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2699779-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2709630-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2709981-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2718704-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2655992-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2691442-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2698365-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2708075-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2757638-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2661254-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2729094-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2712808-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2732487-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2732500-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\IE9-Windows6.1-KB2792100-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2705219-v2-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Windows6.1-KB2731771-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2732059-v5-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2719857-x64.msuE:\ServicePacks-Install\Win_7\XP-Mode\WindowsXPMode_de-de.exeE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2736233-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2739159-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2741355-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2743555-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\windows6.1-kb2647753-v4-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2749655-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2779562-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2604115-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2656356-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2656411-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2789645-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2761217-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2727528-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\windows6.1-kb2685813-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2729452-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2750841-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\windows6.1-kb2685811-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2763523-x64.msuE:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-ActiveX-x64.cabE:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Aux-TopLevel-x64.cabE:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Core-TopLevel-x64.cabE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2770660-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2769369-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2785220-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2726535-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2773072-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2786081-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2786400-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2736422-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2742599-x64.msuE:\ServicePacks-Install\Win_7\Updates-Maerz\Framework\3.51\Windows6.1-KB2756921-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\IE9-Windows6.1-KB2797052-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2778344-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2790113-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2790655-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2799494-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2760730-v2-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2779272-x64.msuE:\ServicePacks-Install\Win_7\Dr.Windows_Update_Pack\win7_updatepack_40_x64\patches\Windows6.1-KB2574819-x64.msu#WallpapersE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\100_0001.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\100_0045_0001_NEW.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\100_0045_0001_NEW_16_10.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\100_0045_0001_NEW_16_9.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\AfternoonSun.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\alta-badia.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\AmwayTravelBeach_1280x1024b.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\AmwayTravelSun_1280x1024.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Arch_Bridge.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Arches_National_park.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Bald_Eagle.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Black_Cat.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Bridge.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Calico_Cat.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\CanyonWater.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Cat_in_a_basket.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Cheetahs.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Cherry_Trees.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Coral_Reef.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\DreamBay.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Duomo_MI.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Frog.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Genitori.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Green_Sea_Turtle.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Hana_Highway.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Hawaii-Welle.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Haze.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Kihei_Maui.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Manarola.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Moos.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Mountains.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Naldi.JPGE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Naptime.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\nascosto_nell_erba.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\primo_piano_leone.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Reflecting_Pond.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Sailboot_at_Sunset.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\seaofconero.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Silence.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Snow.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Swan.jpgE:\ServicePacks-Install\Win_7\Windows_Wallpapers\Tiger_Cub.jpgE:\ServicePacks-Install\Win_7\Extra-Win7\Wallpapers\Wolf.jpg#OptionsCompatibility CheckDelete Silent InstallersEnable BeepEnable CMDForce UnsignedLog Registry ChangesPrepare DriversPrompt AddonsPrompt DriversPrompt GadgetsPrompt SilentPrompt ThemesPrompt UpdatesPrompt WallpapersRebuild Image Gruß, Thiersee Edited February 24, 201312 yr by Thiersee
February 24, 201312 yr Author Hi, wow big ini with all m y last trys i saw ie9 always in english, i switched to sfx because with installer i also install greenshot, greenshot opens a forced website after installing, then i always saw ie9 in english but german language pack was integrated. Is it important to have language pack integration on a special position in the list? Greetz X23
February 24, 201312 yr ...Is it important to have language pack integration on a special position in the list? Greetz X23No idea, I don't know anymore: I leave it on the first place and it works for me. Gruß, Thiersee
February 25, 201312 yr @Etz I was under the impression that WinToolkit RunOnce was executed before setupcomplete.cmd and not Setupcomplete.cmd and WinToolkit_Runonce after? Possible, use setupcomplete.cmd Here is mine: @echo on:: Set Pagefile Size to 1024MB fixed Sizewmic computersystem where name="%computername%" set AutomaticManagedPagefile=Falsewmic pagefileset where name="C:\\pagefile.sys" set InitialSize=1024,MaximumSize=1024:: Disable Hibernationpowercfg -h off:: Set Network Interfaces MTUnetsh interface ipv4 set subinterface "Wireless Network Connection" mtu=1430 store=persistentnetsh interface ipv4 set subinterface "Local Area Connection" mtu=9014 store=persistent:: Delete Sensitive Setup Informationdel /Q /F "%WinDir%\system32\sysprep\unattend.xml"del /Q /F "%WinDir%\panther\unattend.xml":: Disable RacTask To Get Sleep Working on Overclocked Z68 Boardschtasks.exe /change /tn \Microsoft\Windows\RAC\RacTask /disable:: Fix Windows WMI Event ID:10 Errorcscript %WinDir%\Setup\Scripts\WMI-Error-ID10-Fix.vbs:: Reboot Computer to finish%WinDir%\system32\shutdown.exe -r -f -t 0 It reboots machine, before WinToolkit Installer has started...feel free to customize...
February 25, 201312 yr Author Hi, yeah actually iam using a setupcomplete.cmd with a reboot cmd. Greetz X23
