blagasamuel Posted February 23, 2013 Share Posted February 23, 2013 (edited) Hi!I added all updates from Mcrip. After 9 h and 30 mins( a long time!!!!!), all of the updates were integrated. But i received an error.I attached the image:The text from the error box is: Exception: Tool Name: All-In-One Integrator (1.4.1.14) (Windows 7 ULTIMATE)Image Name: Windows 7 ULTIMATEFileName: "D:\Aplicatii\WinToolkit141-14\Imagex.exe"Argument: /Unmount "C:\WinToolkit_Temp\Mount" /commitWIM File: C:\Win7\sources\install.wimMount Logging: TrueDrive Type: FixedFree Space: 68.38 GBIsReady: TrueFile Exists: TrueDirectory Exists: TrueFiles: Directories: *C:\WinToolkit_Temp\Mount\$Recycle.Bin *C:\WinToolkit_Temp\Mount\Documents and Settings *C:\WinToolkit_Temp \Mount\PerfLogs *C:\WinToolkit_Temp\Mount\Program Files *C:\WinToolkit_Temp\Mount\Program Files (x86) *C:\WinToolkit_Temp \Mount\ProgramData *C:\WinToolkit_Temp\Mount\Users *C:\WinToolkit_Temp\Mount\WindowsSetting taskbar ProgressSetting taskbar ColourDumping RegistryStartingStartedClosing #0Closing #1Closing #2Detecting cause of error #1Detecting cause of error #2Detecting cause of error #3Detecting cause of error #4 ImageX Tool for WindowsCopyright © Microsoft Corp. All rights reserved.Version: 6.1.7601.21716Committing: [C:\WinToolkit_Temp\Mount]...[ ERROR ] C:\WinToolkit_Temp\Mount\Windows\System32\config\SOFTWARE (Error = 32)Unmount Error: Changes to the Image could not be commited.More Info:The process cannot access the file because it is being used by another process. FixedC:\68.38 GB Please help me. Unlocker 64 bit says that nobody uses the proces imagex.exeI am not gonna give OK on the error until i receive some help. Some Details:-Windows 7 ultimate x64 image is downloaded from Microsoft.-I don't have any spaces anywhere in the path or image-I am an administrator. But i did not run wintoolkit.exe with the right click option 'Run as administrator"-I have Over 50 GB free space on C partition.-I don' t have antivirus for the moment.-I use the latest stable version 1.4.1.14-I am using WIndows 7 Ultimate 64 bit-I am working on windows 7 utimate x64 image-No i didn' saved the log file. I use rollback rx latest version, because i could not delete C:\WinToolkit_Temp\Mount. They were to many files and some files i just could not delete them. Unlocker did not saved me. Please help!Sory for my english. Edited February 23, 2013 by blagasamuel Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 23, 2013 Share Posted February 23, 2013 You can try: 1 - Check inside the registry if this key exits and remove if there is a random value: Del_WIM.regWindows Registry Editor Version 5.00; remove corrupted or incorrectly unmonted image[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WIMMount\Mounted Images]2 - Remove existing Temp folder ! You must disable system restore when running Windows image filter. Windows imaging filter might behave unexpectedly when copying files into the mount point. More infos:http://technet.microsoft.com/en-us/library/dd744298(v=ws.10).aspx http://technet.microsoft.com/en-us/library/dd799302(v=ws.10).aspx 3 - Try again and let us know, please. Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 24, 2013 Author Share Posted February 24, 2013 Hi!Sorry for this late reply. 1. In registry:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WIMMount\Mounted Images\85515575-192a-4ce7-a739-0792b4d88c6c I have deleted the entire folder \85515575-192a-4ce7-a739-0792b4d88c6c from registryI have searched the the registry but i did not find anything that matches with : Del_WIM.reg or Del_WIMSystem Restore was disabled when i did the job. I have checked.At point 2 you are telling me to delete the temp folder. If you reffer to:C:\Users\Sherlock Holmes\AppData\Local\Temp\WinToolkit-it's emptyC:\WinToolkit_Temp\Mountit;s imposible to delete this folder because it contains 65,506 Files, 13,405 Folders. And most of the files, windows does not let me to delete them, even Unlocker 64 bit can't do it. Only Rollback RX can do it. But that means to delete everything and start over again like nothing happened at all.I remember a few days ago that one single time worked to save the image. The problem was that i did not noted how it happened that. Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 24, 2013 Share Posted February 24, 2013 Try Shift+Del to remove the temp folder! Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 24, 2013 Author Share Posted February 24, 2013 I did as you said shift + delit gives me this error like i told you before.http://postimage.org/image/tglndyrsf/full/ Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 24, 2013 Share Posted February 24, 2013 It's about removing : C:\WinToolkit_Temp\Mount Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 24, 2013 Author Share Posted February 24, 2013 (edited) I know that. So what do i click for this error: "try again" or skip?I have searched google and i stiil search but can't find a fix. Edited February 24, 2013 by blagasamuel Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 24, 2013 Author Share Posted February 24, 2013 I choosed skip, and after that it shows me this error:http://postimage.org/image/rv6dm5hkf/ Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 24, 2013 Author Share Posted February 24, 2013 I choosed skip and after that gives me this error:http://postimage.org/image/yzo6v6otr/ Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 24, 2013 Share Posted February 24, 2013 (edited) Reading a new time the error message it seems there is an error typo inside the command: FileName: "D:\Aplicatii\WinToolkit141-14\Imagex.exe" Word: Applicatii need to be changed to Application *Edit: Try to extract WinToolkit141-14.zip to C:\WinToolkit141-14 and launch WinToolkit.exe Edited February 24, 2013 by myselfidem Quote Link to comment Share on other sites More sharing options...
mooms Posted February 24, 2013 Share Posted February 24, 2013 You have to let Wintoolkit delete the temp folder for you, because you don't have the rights to do it as you have seen. Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 26, 2013 Share Posted February 26, 2013 I've finally manged to replicate this issue, I had to restart my computer and manually unmount the image. I will fix it after further testing CrAzYs and blagasamuel 2 Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 26, 2013 Author Share Posted February 26, 2013 Hi! Sorry for not answering.Thanks for the help. If i will wait for Win toolkit to delete the temp folder i will have to wait a a lot of time.I will test your sugestion tomorrow and see if it works. Thanks for the support . Quote Link to comment Share on other sites More sharing options...
CrAzYs Posted February 26, 2013 Share Posted February 26, 2013 Blaga...... This is mean....... Hi! Sorry for not answering.Thanks for the help. If i will wait for Win toolkit to delete the temp folder i will have to wait a a lot of time.You have temporarily solution... so just do it... Lego... is do his best...... he also have a social life.... just appreciated what he is doing.... Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 27, 2013 Author Share Posted February 27, 2013 Hi!I tried what @myselfidem sugested me to do:Try to extract WinToolkit141-14.zip to C:\WinToolkit141-14 and launch WinToolkit.exeIt gives me this error again:Exception: Tool Name: All-In-One Integrator (1.4.1.14) (Windows 7 ULTIMATE)Image Name: Windows 7 ULTIMATEFileName: "C:\WinToolkit141-14\Imagex.exe"Argument: /Unmount "C:\WinToolkit_Temp\Mount" /commitWIM File: C:\Win7\sources\install.wimMount Logging: TrueDrive Type: FixedFree Space: 54.86 GBIsReady: TrueFile Exists: TrueDirectory Exists: TrueFiles: Directories: *C:\WinToolkit_Temp\Mount\$Recycle.Bin *C:\WinToolkit_Temp\Mount\Documents and Settings *C:\WinToolkit_Temp\Mount\PerfLogs *C:\WinToolkit_Temp\Mount\Program Files *C:\WinToolkit_Temp\Mount\Program Files (x86) *C:\WinToolkit_Temp\Mount\ProgramData *C:\WinToolkit_Temp\Mount\Users *C:\WinToolkit_Temp\Mount\WindowsSetting taskbar ProgressSetting taskbar ColourDumping RegistryStartingStartedClosing #0Closing #1Closing #2Detecting cause of error #1Detecting cause of error #2Detecting cause of error #3Detecting cause of error #4 ImageX Tool for WindowsCopyright © Microsoft Corp. All rights reserved.Version: 6.1.7601.21716Committing: [C:\WinToolkit_Temp\Mount]...[ ERROR ] C:\WinToolkit_Temp\Mount\Windows\System32\config\SOFTWARE (Error = 32)Unmount Error: Changes to the Image could not be commited.More Info:The process cannot access the file because it is being used by another process. FixedC:\54.86 GB Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 27, 2013 Author Share Posted February 27, 2013 Blaga...... This is mean....... You have temporarily solution... so just do it... Lego... is do his best...... he also have a social life.... just appreciated what he is doing.... Hi ! I think you missunderstood me. I really apreciate Lego and his team for the hard work that is done here. Besides work they ive everything fro free which is totally amazing. I respect Lego and his team.And I know that he is human , not a machine. CrAzYs 1 Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 27, 2013 Author Share Posted February 27, 2013 I've finally manged to replicate this issue, I had to restart my computer and manually unmount the image. I will fix it after further testing Hi! Thanks for trying. If you fix this in the future (beta) please let me know. Thanks for the hard work! Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 27, 2013 Share Posted February 27, 2013 (edited) Tested on my computer without error! Windows 7 SP1 32bit Windows 7 ULIMATE_73060.log[4808] [ INFO ] Mounting new image.Wim: [C:\Win7_SP1\sources\install.wim]Image Index: [5]Mount Path: [C:\WinToolkit_Temp\Mount][4808] [ INFO ] Wimserv process started for guid b1a8e278-35ca-4ce5-b14d-56211b428514. Id is 4132[4132] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at C:\Win7_SP1\sources\install.wim.[4132] [ INFO ] Mounted image at C:\WinToolkit_Temp\Mount.[4132] [ INFO ] Received unmount request for image with guid b1a8e278-35ca-4ce5-b14d-56211b428514.[4132] [ INFO ] Unmount for image at C:\WinToolkit_Temp\Mount complete. Maybe there is a trouble with Windows 7 x64? Note:If the temp folder exists (C:\WinToolkit_Temp\Mount) try to remove this one.Create a new temp folder with same names and launch a new time WinToolkit.exe Edited February 27, 2013 by myselfidem Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 28, 2013 Author Share Posted February 28, 2013 Hi!I think my windows 7 sp1 orignal from microsoft is messed up. I will do today a fresh install of windows 7. I'm sure that others from this forum have windows 7 64 bit and they did not complained about this error that i get. Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted February 28, 2013 Author Share Posted February 28, 2013 A user who has windows 7 64 bithttp://www.wincert.net/forum/topic/10626-error-to-commit-image/?hl=%2Bcommit+%2BimageThe looks like mine but it's different at the end. Quote Link to comment Share on other sites More sharing options...
myselfidem Posted February 28, 2013 Share Posted February 28, 2013 Have you tried this one?:http://www.wincert.net/forum/files/file/12-windows-7-sp1-refresh-iso/ Quote Link to comment Share on other sites More sharing options...
blagasamuel Posted March 1, 2013 Author Share Posted March 1, 2013 Have you tried this one?:http://www.wincert.net/forum/files/file/12-windows-7-sp1-refresh-iso/Yes , I didThis is the imagehttp://msft.digitalrivercontent.net/win/X17-59465.iso X17-59465.iso Windows 7 Ultimate x64 English Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted March 2, 2013 Share Posted March 2, 2013 Try this if you it won't unmount: Dism /Remount-Wim /MountDir:<path_to_mount_directory> Then try unmounting again via WIM Manager CrAzYs 1 Quote Link to comment Share on other sites More sharing options...
