Posted March 2, 201312 yr I don't know if it's a "bug or feature" in the new release: IE9, KB2792100 and KB2797052 goes red and I have only IE8 in my installation; with Test_15 no issue and IE9 installs. Regards, Thiersee P.S.: I don't want to install IE10, because there is no access to Microsoft-Update for "Other Software" anymore, see the result: Edited March 3, 201312 yr by Thiersee
March 3, 201312 yr I'm confused... what new release? On 3/2/2013 at 9:55 PM, Thiersee said: I don't know if it's a "bug or feature" in the new release: IE9, KB2792100 and KB2797052 goes red and I have only IE8 in my installation; with Test_15 no issue and IE9 installs. Regards, Thiersee P.S.: I don't want to install IE10, because there is no access to Microsoft-Update for "Other Software" anymore, see the result:
March 3, 201312 yr Author On 3/3/2013 at 7:00 AM, bphlpt said: I think the new stable release here. Cheers and RegardsExactly!Of course new release of WinToolkit. Thiersee
March 3, 201312 yr On 3/2/2013 at 9:55 PM, Thiersee said: P.S.: I don't want to install IE10, because there is no access to Microsoft-Update for "Other Software" anymore, see the result: What do you mean by other sofware, I installed IE 10 today morning
March 3, 201312 yr Use the compatibility button on the address bar to access that site. Are you integrating IE9 msu, cab or EXE? Ultimate x64, Home Premium x86?...
March 3, 201312 yr Author On 3/3/2013 at 10:13 AM, Legolash2o said: Use the compatibility button on the address bar to access that site. Are you integrating IE9 msu, cab or EXE? Ultimate x64, Home Premium x86?...Where is this button? I don't know it. BTW, IE9.exe, german LP, Win7-Pro x64
March 3, 201312 yr Author On 3/3/2013 at 9:57 AM, amaltom61 said: What do you mean by other sofware, I installed IE 10 today morningOffice 2010, Bing-Desktop and other MS-Software, that does not appear, if you don't activate the site. Edited March 3, 201312 yr by Thiersee
March 3, 201312 yr So use to looking in the beta releases that I didn't check that thanks :oops: On 3/3/2013 at 7:00 AM, bphlpt said: I think the new stable release here. Cheers and Regards On 3/3/2013 at 8:42 AM, Thiersee said: Exactly!Of course new release of WinToolkit. Thiersee
March 3, 201312 yr Author On 3/3/2013 at 11:12 AM, Legolash2o said: If you refresh the page it will appear in the address bar.I found it, TNX; it comes only with "old-fashion" sites. Thiersee P.S.: I get an issue with IE10 too, but I open a new thread for it.
