[SOLVED] KB958559 (Virtual PC) pretends Office 2007 from Installation until a reboot
ATTENTION:
Problem itselfs isn't solved but i know how to workaround it!
Hi,
one of the automatically updates must pretend office 2007 from installing,
i get a error 1935and office 2007 rolls back.
http://support.microsoft.com/kb/926804/en
If i install office 2007 before i press the start button from installer, office installs
fine so it must be one of the following:
Any idea which?
Afaik i updated dot net 4.5 to the latest reaper pakage, added the Exchange Certifikate (just a batch that triggers certmgr)
Silverlight and the latest Malicious Software Removal...
Office was always working with my latest tests before.
Greetz X23
Edited by x23piracy
Hi,
i temporarily disabled the following 3 automatic installs:
dot net framework 4.5 installer (latest) reaper
Windows6.1-KB958559-x64-RefreshPkg (Virtual PC)
Silverlight-x64
All of them normally install before Office 2007, lets think... reapers installers have allways worked without a problem,
i dont see any reason why virtual pc should block office from install.
Afai remember silverlight is a single install update over windows update, but i dont know if it request a reboot?
Should i start with only disabling silverlight?
EDIT:
IT's not Silverlight
EDIT2:
IT's not Reapears Dot net framework 4.5
i hope its virtual pc then if not iam really confused ;)
I will report later
Greetz X23
Edited by x23piracy
Hi,
i allready got them as sfx, i found the disturbing pakage, it was virtual pc.
I need to install that as last! or at least after Office 2007!!!
Greetz X23
Edited by x23piracy
curious, do you know why?
Hi,
no i couldnt figure that out everything microsoft says to error 1935 is make a reboot and then it works.
It must be a component from virtual pc that changes something in the system so that office 07 doesnt install.
Greetz X23
