Posted March 4, 201312 yr Hi, from my experiences from the last 3-4 week i had problem with integration of the following updates and actually i install them as sfx: kb2603229kb2533552rvkrootsSilverlightIE9 Language Pack (afaik was integrated but ie was still english not german)Microsoft Malicious Software Removal" DefinitionsDot.Net 4.5 Framework (using Reapers)Virtual PC (KB958559-x64-RefreshPkg) Who has successfully integrated one or more of these updates and with what version oft wtk? Greetz X23 Edited March 4, 201312 yr by x23piracy
March 4, 201312 yr .......kb2603229kb2533552rvkrootsSilverlightIE9 Language Pack (afaik was integrated but ie was still english not german)....Virtual PC (KB958559-x64-RefreshPkg)...... Every version! I don't integrate: Microsoft Malicious Software Removal DefinitionsDot.Net 4.5 Framework (using Reapers) (I use McRip) Gruß, Thiersee
March 4, 201312 yr Author Hi, Every version! means you have integrated the stuff you've listed?hmmm i should try again. Can i integrate them all raw or must i extract some of them? Greetz X23
March 4, 201312 yr You cant integrate them but wtk can add them to your iso and stage them for install
March 4, 201312 yr Yes Sir! All as silent-installer (not of course IE9 LP!), Virtual PC with option Prompt.I didn't extract anything. Gruß, Thiersee P.S.: I don't use McRip's Windows-Updates.
March 4, 201312 yr Author Hi, Yes Sir! All as silent-installer (not of course IE9 LP!), Virtual PC with option Prompt. yeah actually they are all silent installers here but i thougth of the possibility to have them as updates.What do you mean with virtual pc option prompt, you mean not auto install right? Greetz X23
March 4, 201312 yr Hi, yeah actually they are all silent installers here but i thougth of the possibility to have them as updates.What do you mean with virtual pc option prompt, you mean not auto install right? Greetz X23Both KBs can be installed only on a running Windows, i.e. they can NOT be slipstreamed!Virtual PC: yes, not auto-install. Gruß, Thiersee
March 4, 201312 yr Author Hi, Virtual PC: yes, not auto-install. do you have it as one of you last positions on the list to install?If i install virtual pc before trying to install office 2007, office 2007 fails.Install only possible after a reboot. I figured this behaviour out today, and it was the last of my suspects, what else... Do i need any switch for virtual pc to install silently while no automatic install? Greetz X23 Edited March 4, 201312 yr by x23piracy
March 4, 201312 yr ...... do you have it as one of you last positions on the list to install?......No, is the first one of the installers without auto-install.But I don't install Office 2007... Gruß, Thiersee
March 4, 201312 yr Author Hi, But I don't install Office 2007... one of your best decisions :owned: i banned my virtual pc installation... last but not least devilish... Greetz X23 Edited March 4, 201312 yr by x23piracy
March 4, 201312 yr I use Office 2010 with two different config and two different languages, german and italian, so I prefer to install it manually. Gruß, Thiersee
