Hello:
Thank you for such an invaluable tool!
In both the '17 and '18 builds of WinToolKit, progress seems to stall at KB2729462,   It is the first of 36 updates (in the Tookit list) that I downloaded with WindowsUpdate Downloader.   After half-an-hour in each instance, I gave up. My preset was fairly simple and straightforward; a few device drivers, a few registry tweaks, and the updates.  I downloaded the '14 build, and it is working perfectly.
Building Windows 8 x86 image.
