Can't thank you guys enough for all the work that gets put into WinToolKit.  I just wanted to report a two KB's that had errors during integration on Windows 8.
What Happened:
When using Win ToolKit 1.4.1.18 on Windows 8 Enterprise x64, I experienced an error when attempting to install two specific updates.
KB2771431 = Failed to integrate
KB2774195 = Failed to integrate
Note:
Legacy .NET Framework is enabled in WinTookit Options.
1 Error was reported but both KB's fail.
Title: 1 error(s) have occurredErrType: Error (1.4.1.18)Description: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception: Exception:An error occured whilst integrating an update!Exception:Microsoft Windows [Version 6.2.9200](c) 2012 Microsoft Corporation. All rights reserved.Z:\Software\WinToolKit>Set SEE_MASK_NOZONECHECKS=1Z:\Software\WinToolKit>"C:\Windows\System32\Dism.exe"  /Image:"C:\WinToolkit_Mount" /Add-Package /PackagePath:"Y:\Update\WINDOWS8-RT-KB2771431-X64.MSU" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.2.9200.16384Image Version: 6.2.9200.16384Processing 1 of 1 - Y:\Update\WINDOWS8-RT-KB2771431-X64.MSU: An error occurred applying the Unattend.xml file from the .msu package.For more information, review the log file. Error: 0x800f082eError: 0x800f082eDISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logZ:\Software\WinToolKit>exit----------------------------------
The Following updates were selected for integration:
    IE10-WINDOWS8-RT-KB2792100-X64.MSU    WINDOWS6.2-KB2779444-X64.MSU    WINDOWS8-RT-KB2727528-X64.MSU    WINDOWS8-RT-KB2729462-X64.MSU    WINDOWS8-RT-KB2736693-X64.MSU    WINDOWS8-RT-KB2737084-X64.MSU    WINDOWS8-RT-KB2742614-X64.MSU    WINDOWS8-RT-KB2742616-X64.MSU    WINDOWS8-RT-KB2750149-X64.MSU    WINDOWS8-RT-KB2751352-V2-X64.MSU    WINDOWS8-RT-KB2753842-V2-X64.MSU    WINDOWS8-RT-KB2756872-X64.MSU    WINDOWS8-RT-KB2757638-X64.MSU    WINDOWS8-RT-KB2768703-X64.MSU    WINDOWS8-RT-KB2769034-X64.MSU    WINDOWS8-RT-KB2769165-X64.MSU    WINDOWS8-RT-KB2769166-X64.MSU    WINDOWS8-RT-KB2770660-X64.MSU    WINDOWS8-RT-KB2770816-X64.MSU    WINDOWS8-RT-KB2771431-X64.MSU    WINDOWS8-RT-KB2774195-X64.MSU    WINDOWS8-RT-KB2777294-X64.MSU    WINDOWS8-RT-KB2778344-X64.MSU    WINDOWS8-RT-KB2779562-X64.MSU    WINDOWS8-RT-KB2779768-X64.MSU    WINDOWS8-RT-KB2780541-X64.MSU    WINDOWS8-RT-KB2785094-X64.MSU    WINDOWS8-RT-KB2785220-X64.MSU    WINDOWS8-RT-KB2789649-X64.MSU    WINDOWS8-RT-KB2789650-X64.MSU    WINDOWS8-RT-KB2790655-X64.MSU    WINDOWS8-RT-KB2792476-X64.MSU    WINDOWS8-RT-KB2793210-X64.MSU    WINDOWS8-RT-KB2794119-X64.MSU    WINDOWS8-RT-KB2794599-X64.MSU    WINDOWS8-RT-KB2795944-X64.MSU    WINDOWS8-RT-KB2797052-X64.MSU    WINDOWS8-RT-KB2799494-X64.MSU    WINDOWS8-RT-KB2803676-X64.MSU    WINDOWS8-RT-KB2805940-X64.MSU    WINDOWS8-RT-KB2818604-X64.MSU    WINDOWS8-RT-KB2819372-X64.MSU    WINDOWS8-RT-KB917607-X64.MSU
Well! In that case remove from the update list!
Hardly the point of doing this, is it?
EDIT,
Going do do some testing, will post back later.
Edited by Stimpy
OK, installing KB2771431 as a silent install worked perfectly. It shows up as an installed update, and everything is installed.
I used 1.4.1.19Test1 for the integration.
I've made it so updates which receive 0x800f082e errors get automatically added to the silent installers list and make the item go peach instead of pink/red.
I could probably make it so that all failed updates go into silent installer automatically, but that can end badly.
Peach, I could eat a peach for hours!
Nice work Lego! Thanks.
I'm just going to give Test 2 a quick spin, and see how it goes.
I will report back in a little while.
UPDATE 1
OK, 19 minutes later, I have 80 updates installed successfully. Even the peach one!
I'm just installing it in a VM to verify everything.
UPDATE 2
Yep, everything's fine in the VM, and all updates installed correctly.
Many thanks Lego!
Edited by Stimpy
KB2771431 Works as advertised.  Awesome work indeed.  No errors were thrown with during integration this time around.  This was of course tested with WinToolkit 1.4.1.19 test 2 and Windows 8 Enterprise x64.
I can see that KB2774195 is still acting up but I don't think WINDOWS8-RT-KB2774195-X64.MSU is intended for my platform.
EDITED:
http://support.microsoft.com/kb/2774195
KB2774195 is for ITALIAN versions of Windows 8 with IE10.  So no problems here.
post-43405-0-83017800-1362692522_thumb.p
Edited by splinterededge
