Posted (edited)
Hi,
is it possible to setup native solution with unattend.xml?
Would be nice so i dont need to decide between a good resolution for 4:3 or 16:9(10)
Greetz X23
Edited by x23piracy
Yep, but this involves that windows either has some native drivers for the video card (older video cards, that came out before for ex. windows 7 came out), or you slipstream yourself those newer video drivers. I for one never slipstreamed video drivers in any modified windows .iso, as those video drivers can be pretty tricky, and the ''control panel'' that comes with them isn't just for show in most cases. :)
Posted (edited)
Hi, i should test this:
To have Windows automatically use the optimal resolution, you can simply leave the Microsoft-Windows-Shell-Setup | Display blank, or if using MDT which populates this component, delete it and add it back unpopulated.
I will report back if that is working. Greetz X23
Edited by x23piracy
