ClipName
Description
ClipName is also a Context Menu extension copying the full pathname of the right-clicked file to the clipboard.
Version: 1.3.0
Platform: x86 & x64
Addon Release Date: March 11, 2013
Uninstallable: Yes
Credit: *Reaper*
NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.
Must use Win Toolkit 1.4.1.14 or higher!
Size.png - 102 kb
MD5.png - df4645fb7d91283b05209a2e44ca8bfe
Enjoy!
Edited by *Reaper*
  • 9 months later...
