Posted March 11, 201312 yr Hi, I am currently testing Win Toolkit 1.4.1.21 and when I launch it I always get this error like 40 times, after clicking those away I get to the main interface, but when chosing for example component removal I also get this error again: Major ErrorMissing reference. Please report this immediately: WinToolkit.resources
March 12, 201312 yr I have deleted your other post. Please don't double post. It may take a little time, but someone will try and help you with your problem.
March 12, 201312 yr I havn't seen this myself, i'll be running 1.4.1.21 for a third full run today and will report if I have any problems. In the meantime maybe you can double check the normal stuff like .NET Framework 3.5 and if your running wintoolkit from xp or vista you will need the dism installer from the download area. Are you running WintoolKit from Windows XP, Vista, 7 or 8? Maybe post of a copy of a your wintoolkit log files so we can take a look at the detail of the error. Edited March 12, 201312 yr by splinterededge
March 12, 201312 yr I've never encounter this problem on win toolkit 1.4.1.21 & I'm using win7 x64 OS.
March 12, 201312 yr I have deleted your other post.Please don't double post. It may take a little time, but someone will try and help you with your problem.The reason for the double post is it was his first, so it was waiting to be approved and he posted a second one not knowing this
March 16, 201312 yr Hi, The reason for the double post is it was his first, so it was waiting to be approved and he posted a second one not knowing this then it's a forum bug for me because he should get the warning message again and again until his first post was approved Greetz X23
March 18, 201312 yr Any error logs? What Windows are you using? Tried disabling your anti-virus? Any sort of additional information?
