Gideon Posted March 12, 2013 Posted March 12, 2013 (edited) Hi all, I see a lot of posts with this word preceding the title: [sOLVED]. How do I add [sOLVED] to the title of my posts?Thanks, Gideon. Edited March 12, 2013 by Gideon Quote
bphlpt Posted March 12, 2013 Posted March 12, 2013 (edited) Only the OP, or a mod/admin can do this. If you are the OP, then click the "Edit" button in the first post in the thread as if you are going to edit the first post. When the edit box opens, click the "Use Full Editor" button at the bottom of the edit box. When the full editor opens, make whatever changes you need in the "Topic Title" box, then click "Save Modified Post" at the bottom of the Edit Post block. Cheers and Regards Edited March 12, 2013 by bphlpt Quote
