@mooms
Could you give me a link to try WinToolkit 1.4.15 test 15 to test it?
Maybe MediaFire?
Seems you have integrated IE10 successfully.
Many thanks in advance
*Edit: However there was an typo error about installing IE10 on my french OS computer with Windows Update!
http://www.msfn.org/board/topic/159082-internet-explorer-10/page__view__findpost__p__1033067
Edited by myselfidem
  • Replies 94
  • Views 24.1k
  • @RicaNeaga: I Kow you wanted to help and I thank you for that but I said multiple times and since the first post that a previous version of WinToolkit can integrate the French IE10 LP just fine, so I
  • Legolash2o
    Legolash2o
    So the problem is because 'IE10 & KB2786081' are not pushed into the prerequisites list? Mooms, what did you do different to that they wan't in the prerequisites list. Did you import the last sess
  • Legolash2o
    Legolash2o
    VirtualBox just finished installing. IE10 menu's were in FRENCH
@RicaNeaga: I Kow you wanted to help and I thank you for that but I said multiple times and since the first post that a previous version of WinToolkit can integrate the French IE10 LP just fine, so I think we can safely draw the conclusion that this is not a MS bug in this case.
@myselfidem: Only cab/msu (not IE10 exe directly) can be integrated with test15. I will post links and explanation in the French section in a minute.
mooms +1
15 or later versions have a language pack integration problem.
Not only French, i have Turkish and have same problem.
This is not microsoft problem.
IE10 Turkish is added fine with WinToolkit 1.4.1.22. Tested
And english, german and italian too......
Yes, tested and reported #post 24. Thanks
Seems an Microsoft error inside IE10-Windows6.1-x86-fr-fr.exe...But where?
Yes mooms, ielangpack-TRK.CAB.
@myselfidem
IE10 Turkish is added fine, but not working. All string is english. Windows update show IE Language pack Turkish.
So the bug is not only for French.
Made new tests yesterday:
Here is the ini of v22: (LP appears to be integrated but not installed)
*AIO
#Services
Windows Error Reporting::Disabled
Windows Search::Disabled
#Silent Installs
270312vcredist::;NO;10.77 MB;F:\win7\switchless\270312vcredist.exe;Always Installed
CCleaner_3281913::;NO;3.10 MB;F:\win7\switchless\CCleaner_3281913.exe;Always Installed
DXrt32::;NO;13.04 MB;F:\win7\switchless\DXrt32.exe;Always Installed
firefox_1902_ext::;NO;21.78 MB;F:\win7\switchless\firefox_1902_ext.exe;Always Installed
Flash_activeX::;NO;15.33 MB;F:\win7\switchless\Flash_activeX.exe;Always Installed
Flash_Plugin::;NO;15.94 MB;F:\win7\switchless\Flash_Plugin.exe;Always Installed
hashchk::;NO;56.00 KB;F:\win7\switchless\hashchk.exe;Always Installed
KB976002-x86::;NO;262.73 KB;F:\win7\switchless\KB976002-x86.msu;Always Installed
KB2533552-x86::;NO;4.07 MB;F:\win7\switchless\KB2533552-x86.msu;Always Installed
KB2592687-x86::;NO;4.35 MB;F:\win7\switchless\KB2592687-x86.msu;Always Installed
rootsupd::;NO;383.63 KB;F:\win7\switchless\rootsupd.exe;Always Installed
SFX_CMDopen::;NO;120.61 KB;F:\win7\switchless\SFX_CMDopen.exe;Always Installed
SFX_Everything_13062b::;NO;526.80 KB;F:\win7\switchless\SFX_Everything_13062b.exe;Always Installed
SFX_klcpf980::;NO;18.82 MB;F:\win7\switchless\SFX_klcpf980.exe;Always Installed
SFX_np2mod::;NO;1.11 MB;F:\win7\switchless\SFX_np2mod.exe;Always Installed
SumatraPDF221::;NO;4.70 MB;F:\win7\switchless\SumatraPDF221.exe;Always Installed
thunderbird1704::;NO;19.04 MB;F:\win7\switchless\thunderbird1704.exe;Always Installed
utilitaires_sfx::;NO;11.86 MB;F:\win7\switchless\utilitaires_sfx.exe;Always Installed
Winrar420Fr_AiO::;NO;3.03 MB;F:\win7\switchless\Winrar420Fr_AiO.exe;Always Installed
dotNetFx45_x86_x64_Fr::;NO;47.84 MB;F:\win7\switchless\dotNetFx45_x86_x64_Fr.exe;Always Installed
#Tweaks
Add 'Unpack' to *.msi context menu
Show 'Computer' on Desktop
Control Panel View::Large Icons
Disable Desktop Preview [Win7]
Disable Search Online on Unknown File Extensions
Show File Extensions
Show Hidden Files & Folders
Disable Auto Reboot after installing updates
Enable DVD in Media Player
Open NFO files with notepad
Clear History on Exit
Disable Default Browser Check
Disable First Run Customize
Disable Signature checking for EXEs
Disable Warning on Close (Tabs)
IE Homepage::about:blank
Turn On Clear Type
Enable MSI Service in Safe Mode
Disable Automatic Restart on BSOD
Disable Dr Watson
Disable Windows Error Reporting
tweaks.reg::F:\win7\tweaks.reg
#Updates
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2479943-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2484033-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2488113-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2491683-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2502285-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2503665-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2505438-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2506212-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2506928-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2509553-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2511250-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2511455-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2515325-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2522422-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2529073-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2532531-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2536275-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2536276-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2541014-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2544893-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2545698-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2547666-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2552343-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2560656-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2563227-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2564958-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2570947-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2574819-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2579686-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2584146-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2585542-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2604115-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2619339-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2620704-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2620712-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2621440-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2631813-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2640148-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2644615-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2647753-v4-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2653956-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2654428-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2655992-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2656356-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2656411-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2658846-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2659262-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2660075-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2660649-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2661254-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2667402-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2670838-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2676562-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2677070-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2679255-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2685811-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2685813-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2685939-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2690533-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2691442-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2698365-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2699779-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2705219-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2709630-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2709981-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2712808-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2718704-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2719857-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2719985-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2726535-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2727528-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2729094-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2729452-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2731771-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732059-v5-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732487-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732500-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2735855-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2736233-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2736422-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2739159-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2741355-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2742599-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2743555-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2749655-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2750841-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2753842-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2756822-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2756921-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2757638-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2758857-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2761217-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2763523-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2769369-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2770660-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2773072-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2778344-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2779562-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2785220-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2786081-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2786400-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2789645-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2790113-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2790655-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2791765-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2799494-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2807986-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB971033-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB982018-v3-x86.msu
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-ActiveX-x86.cab
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-Aux-TopLevel-x86.cab
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-Core-TopLevel-x86.cab
F:\win7\7SP1_X86_UpdatePack\z1-IE-Win7.CAB
F:\win7\7SP1_X86_UpdatePack\z2-ielangpack-FRA.CAB
F:\win7\7SP1_X86_UpdatePack\z3-IE-Hyphenation-NEU.MSU
F:\win7\7SP1_X86_UpdatePack\z4-IE-Spelling-NEU.MSU
F:\win7\7SP1_X86_UpdatePack\z5-IE-Hyphenation-FRA.MSU
F:\win7\7SP1_X86_UpdatePack\z6-IE-Spelling-FRA.MSU
#Options
Compatibility Check
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
 WinToolkit window:
Here is the ini of test15: (LP installed) :
*AIO
#Services
#Silent Installs
#Tweaks
Turn On Clear Type
Disable Dr Watson
#Updates
#Options
Compatibility Check
Create Backups
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
 WinToolkit window:
We can see that prerequisites are not integrated in the same order (and IE10 & KB2786081 are not pushed in prerequisites in test15).
Also KB2574819 and KB2670838 are inverted in the ini.
Question: Why aren't you integrating also the KB2533623 prerequisite with build 22? It's needed although it's superseeded - see here. I noticed it since you have only four prerequisites installed instead of five. :)
Thanks RicaNeaga!
Tested also with this update and doesn't work. IE10 is in English and not French!
2013-03-21_14-21-56.ini
*AIO
#Updates
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB911589-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB917607-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB949843-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB967351-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB972959-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB973817-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB976042-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB982018-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB982559-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2276594-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2280390-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2394535-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2401553-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2417168-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2427341-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2443643-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2446607-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2456741-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2457458-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2461631-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2462182-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2465285-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2466048-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2466493-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2467167-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2472264-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2475491-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2477932-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2479943-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2480641-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2480994-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2483564-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2486635-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2486644-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2493006-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2493989-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2495313-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2495786-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2496898-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2502789-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2503784-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2506628-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2506928-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2508120-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2509318-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2511455-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2512352-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2514642-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2516889-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2519400-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2519646-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2519735-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2519922-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2520487-v4-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2521416-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2521624-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2521923-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2524732-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2524977-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2526629-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2529781-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2529825-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2535158-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2536840-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2537203-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2538047-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2540175-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2541014-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2545561-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2546868-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2549067-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2549079-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2550648-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2554231-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2554859-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2554876-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2555189-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2555392-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2555948-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2560656-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2563227-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2564958-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2569389-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2570947-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2575866-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2575928-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2577968-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2578214-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2579686-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2582679-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2584454-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2584475-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2584577-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2588507-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2591271-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2591500-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2591857-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2599437-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2600100-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2600484-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2601207-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2603203-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2604115-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2612905-v4-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2613988-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2614066-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2614892-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2615327-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2615701-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2616332-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2616386-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2616879-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2618301-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2618535-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2618640-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2619234-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2619260-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2619339-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2619836-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2620704-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2620712-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2621440-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2624868-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2625737-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2627273-v4-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2627489-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2631813-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2635500-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2636056-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2636963-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2638018-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2639043-v5-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2639077-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2639320-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2640148-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2640472-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2641618-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2642357-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2644491-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2645594-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2645610-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2647753-v4-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2647878-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2648039-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2649904-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2652029-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2653312-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2653956-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2654428-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2659158-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2659262-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2659440-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2660075-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2660649-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2660677-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2661796-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2662288-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2662585-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2664203-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2665720-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2667402-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2668395-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2674365-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2674705-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2674913-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2675275-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2675611-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2675806-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2680097-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2680243-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2682814-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2683484-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2683913-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2684681-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2684982-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2685088-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2685811-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2685813-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2685889-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2685893-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2686369-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2686795-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2687799-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2687862-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2690528-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2690533-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2691156-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2693187-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2695207-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2696739-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2697479-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2697645-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2697738-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2698155-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2698365-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2698888-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2698957-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2699779-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2699780-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2701239-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2701851-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2701894-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2703639-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2703902-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2704299-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2704377-v6-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2705219-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2705742-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2706051-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2707135-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2707157-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2707589-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2708857-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2709981-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2710594-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2710832-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2712331-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2712561-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2714014-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2715078-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2715992-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2716542-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2717045-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2718646-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2718654-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2718704-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2718841-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719248-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719305-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719306-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719594-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719857-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2719985-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2720568-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2721259-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2722729-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2724133-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2724137-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2724629-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2725604-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2726535-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2727107-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2727118-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2727324-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2727528-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2728379-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2729452-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2729608-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2729670-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2732059-v5-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2732072-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2732500-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2732673-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2732840-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2733955-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2735209-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2736233-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2736422-X86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2736469-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2736782-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2738898-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2739143-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2740180-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2740232-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2741416-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2742185-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2742483-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2742599-X86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2743148-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2743555-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2746119-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2749655-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2750692-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2750841-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2752407-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2753842-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2754704-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2755105-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2755625-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2756198-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2756263-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2756651-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2756921-X86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2757817-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2760730-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2763342-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2765067-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2765546-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2767652-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2767671-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2768486-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2768492-v3-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2768494-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2768523-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2769121-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2769359-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2769791-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2770660-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2773072-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2775511-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2779272-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2780130-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2780410-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2780444-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2781049-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2782486-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2783429-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2784146-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2784148-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2785220-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2786400-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2786464-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2787046-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2789645-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2790113-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2790804-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2790817-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2791765-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2792026-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2796313-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2796725-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2796764-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2796765-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797120-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797136-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797749-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797789-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797822-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2797918-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2798040-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2798286-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2798670-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2798787-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2799360-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2799406-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2799464-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2799603-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2799925-v2-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2800170-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2800422-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2800789-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2801244-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2801423-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2801453-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2801662-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2803752-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2803759-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2805853-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2807716-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2807986-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2810177-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2814923-x86.msu
C:\WinToolkit141-22\Updates\McRip Windows 7 x86\Windows6.1-KB2821346-v2-x86.msu
C:\IE10\Windows6.1-KB2533623-x86.msu
C:\IE10\Windows6.1-KB2670838-x86.msu
C:\IE10\Windows6.1-KB2729094-v2-x86.msu
C:\IE10\Windows6.1-KB2731771-x86.msu
C:\IE10\Windows6.1-KB2786081-x86.msu
C:\IE10\IE10\z1-IE-Win7.CAB
C:\IE10\IE10\z2-IE-Hyphenation-NEU.MSU
C:\IE10\IE10\z3-IE-Spelling-NEU.MSU
C:\IE10\IE10\z4-IE-Hyphenation-FRA.MSU
C:\IE10\IE10\z5-IE-Spelling-FRA.MSU
C:\IE10\IE10\z6-ielangpack-FRA.CAB
#Options
Compatibility Check
Create Backups
Enable CMD
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
Show Duplicates
For me it's not a problem with requisites or integration order.
As I said the LP is working with "cab versions" of IE10 and WinToolkit 1.41-15_Test15, not 1.4.1.21
Yes!
Tested Wintoolkit 1.4.1.15_Test15 you shared,http://www.wincert.net/forum/topic/10811-13-03-2013-update-packs-gdr-pour-windows-7-sp1/page-3#entry97546 ,and IE10 Language FR is integrated successfully!
Seems an problem order inside WinToolkit 1.4.1.22.
I selected first all updates and after prerequisites updates and IE10 extracted folders to insert inside WinToolkit and works fine!
*AIO
#Updates
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB911589-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB917607-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB949843-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB967351-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB972959-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB973817-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB976042-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB982018-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB982559-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2276594-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2280390-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2394535-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2401553-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2417168-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2427341-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2443643-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2446607-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2456741-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2457458-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2461631-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2462182-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2465285-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2466048-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2466493-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2467167-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2472264-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2475491-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2477932-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2479943-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2480641-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2480994-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2483564-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2486635-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2486644-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2493006-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2493989-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2495313-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2495786-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2496898-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2502789-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2503784-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2506628-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2506928-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2508120-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2509318-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2511455-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2512352-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2514642-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2516889-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2519400-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2519646-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2519735-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2519922-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2520487-v4-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2521416-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2521624-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2521923-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2524732-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2524977-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2526629-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2529781-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2529825-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2535158-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2536840-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2537203-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2538047-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2540175-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2541014-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2545561-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2546868-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2549067-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2549079-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2550648-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2554231-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2554859-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2554876-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2555189-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2555392-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2555948-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2560656-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2563227-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2564958-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2569389-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2570947-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2575866-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2575928-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2577968-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2578214-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2579686-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2582679-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2584454-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2584475-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2584577-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2588507-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2591271-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2591500-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2591857-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2599437-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2600100-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2600484-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2601207-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2603203-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2604115-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2612905-v4-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2613988-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2614066-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2614892-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2615327-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2615701-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2616332-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2616386-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2616879-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2618301-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2618535-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2618640-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2619234-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2619260-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2619339-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2619836-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2620704-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2620712-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2621440-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2624868-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2625737-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2627273-v4-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2627489-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2631813-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2635500-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2636056-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2636963-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2638018-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2639043-v5-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2639077-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2639320-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2640148-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2640472-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2641618-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2642357-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2644491-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2645594-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2645610-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2647753-v4-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2647878-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2648039-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2649904-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2652029-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2653312-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2653956-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2654428-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2659158-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2659262-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2659440-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2660075-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2660649-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2660677-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2661796-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2662288-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2662585-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2664203-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2665720-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2667402-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2668395-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2674365-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2674705-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2674913-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2675275-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2675611-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2675806-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2680097-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2680243-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2682814-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2683484-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2683913-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2684681-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2684982-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2685088-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2685811-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2685813-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2685889-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2685893-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2686369-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2686795-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2687799-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2687862-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2690528-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2690533-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2691156-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2693187-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2695207-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2696739-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2697479-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2697645-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2697738-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2698155-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2698365-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2698888-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2698957-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2699779-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2699780-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2701239-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2701851-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2701894-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2703639-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2703902-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2704299-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2704377-v6-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2705219-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2705742-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2706051-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2707135-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2707157-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2707589-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2708857-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2709981-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2710594-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2710832-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2712331-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2712561-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2714014-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2715078-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2715992-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2716542-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2717045-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2718646-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2718654-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2718704-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2718841-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719248-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719305-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719306-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719594-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719857-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2719985-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2720568-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2721259-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2722729-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2724133-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2724137-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2724629-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2725604-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2726535-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2727107-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2727118-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2727324-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2727528-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2728379-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2729452-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2729608-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2729670-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2732059-v5-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2732072-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2732500-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2732673-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2732840-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2733955-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2735209-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2736233-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2736422-X86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2736469-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2736782-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2738898-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2739143-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2740180-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2740232-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2741416-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2742185-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2742483-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2742599-X86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2743148-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2743555-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2746119-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2749655-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2750692-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2750841-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2752407-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2753842-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2754704-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2755105-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2755625-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2756198-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2756263-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2756651-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2756921-X86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2757817-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2760730-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2763342-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2765067-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2765546-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2767652-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2767671-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2768486-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2768492-v3-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2768494-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2768523-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2769121-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2769359-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2769791-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2770660-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2773072-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2775511-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2779272-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2780130-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2780410-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2780444-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2781049-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2782486-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2783429-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2784146-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2784148-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2785220-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2786400-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2786464-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2787046-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2789645-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2790113-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2790804-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2790817-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2791765-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2792026-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2796313-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2796725-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2796764-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2796765-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797120-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797136-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797749-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797789-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797822-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2797918-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2798040-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2798286-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2798670-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2798787-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2799360-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2799406-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2799464-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2799603-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2799925-v2-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2800170-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2800422-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2800789-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2801244-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2801423-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2801453-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2801662-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2803752-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2803759-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2805853-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2807716-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2807986-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2810177-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2814923-x86.msu
C:\WinToolkit141-15_Test15\Updates\McRip Windows 7 x86\Windows6.1-KB2821346-v2-x86.msu
C:\IE10\IE10\z2-IE-Spelling-NEU.MSU
C:\IE10\IE10\z3-IE-Hyphenation-NEU.MSU
C:\IE10\IE10\z4-IE-Spelling-FRA.MSU
C:\IE10\IE10\z5-IE-Hyphenation-FRA.MSU
#Options
Compatibility Check
Create Backups
Enable CMD
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
Show Duplicates
Image Install Order
https://skydrive.live.com/?lc=4108#cid=D178EA021B182B88&id=D178EA021B182B88%211529
Image Updates Integration
https://skydrive.live.com/?lc=4108#cid=D178EA021B182B88&id=D178EA021B182B88%211528
Final Installation Image
Edited by myselfidem
So it's an order issue after all... probably build 15 test 15 wasn't aware of IE10, that's how you were able to integrate it last, right? I mean that the reason IE10 isn't moved by default in the prerequisites area... Win Toolkit doesn't have a rule to add IE10 to the prerequisites area as in the latest build.
If this is really the issue, and I don't see why not, I don't want to dig up an old argument, but I've really never understood why integrate Internet Explorer before the rest of the hotfixes. I made a thread special for this (besides making my point a couple of years ago, when this was first introduced for IE9 and its language packs), see here, so in a way I ''predicted'' this issue.
@Lego  Maybe the order is not the issue, maybe something else is just wrong in Win Toolkit, this really doesn't matter however to my request from here. If such a removal of prerequisites filter would exist for advanced users, and we'd have the liberty to integrate the updates in whatever order we'd want, at least we could better troubleshoot situations like these. :)
Tested WinToolkit 1.4.1.16 and works!
IE10 language FR is integrated successfully!
2013-03-23_11-12-04.ini
*AIO
#Updates
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB911589-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB917607-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB949843-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB967351-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB972959-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB973817-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB976042-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB982018-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB982559-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2276594-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2280390-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2394535-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2401553-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2417168-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2427341-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2443643-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2446607-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2456741-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2457458-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2461631-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2462182-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2465285-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2466048-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2466493-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2467167-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2472264-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2475491-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2477932-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2479943-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2480641-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2480994-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2483564-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2486635-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2486644-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2493006-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2493989-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2495313-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2495786-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2496898-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2502789-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2503784-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2506628-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2506928-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2508120-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2509318-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2511455-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2512352-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2514642-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2516889-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2519400-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2519646-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2519735-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2519922-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2520487-v4-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2521416-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2521624-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2521923-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2524732-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2524977-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2526629-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2529781-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2529825-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2535158-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2536840-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2537203-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2538047-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2540175-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2541014-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2545561-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2546868-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2549067-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2549079-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2550648-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2554231-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2554859-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2554876-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2555189-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2555392-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2555948-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2560656-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2563227-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2564958-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2569389-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2570947-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2575866-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2575928-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2577968-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2578214-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2579686-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2582679-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2584454-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2584475-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2584577-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2588507-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2591271-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2591500-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2591857-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2599437-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2600100-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2600484-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2601207-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2603203-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2604115-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2612905-v4-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2613988-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2614066-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2614892-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2615327-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2615701-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2616332-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2616386-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2616879-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2618301-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2618535-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2618640-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2619234-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2619260-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2619339-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2619836-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2620704-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2620712-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2621440-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2624868-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2625737-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2627273-v4-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2627489-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2631813-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2635500-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2636056-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2636963-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2638018-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2639043-v5-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2639077-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2639320-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2640148-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2640472-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2641618-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2642357-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2644491-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2645594-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2645610-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2647753-v4-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2647878-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2648039-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2649904-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2652029-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2653312-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2653956-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2654428-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2659158-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2659262-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2659440-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2660075-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2660649-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2660677-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2661796-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2662288-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2662585-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2664203-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2665720-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2667402-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2668395-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2674365-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2674705-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2674913-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2675275-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2675611-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2675806-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2680097-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2680243-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2682814-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2683484-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2683913-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2684681-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2684982-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2685088-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2685811-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2685813-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2685889-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2685893-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2686369-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2686795-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2687799-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2687862-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2690528-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2690533-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2691156-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2693187-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2695207-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2696739-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2697479-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2697645-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2697738-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2698155-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2698365-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2698888-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2698957-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2699779-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2699780-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2701239-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2701851-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2701894-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2703639-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2703902-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2704299-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2704377-v6-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2705219-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2705742-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2706051-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2707135-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2707157-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2707589-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2708857-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2709981-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2710594-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2710832-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2712331-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2712561-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2714014-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2715078-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2715992-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2716542-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2717045-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2718646-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2718654-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2718704-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2718841-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719248-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719305-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719306-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719594-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719857-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2719985-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2720568-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2721259-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2722729-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2724133-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2724137-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2724629-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2725604-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2726535-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2727107-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2727118-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2727324-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2727528-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2728379-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2729452-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2729608-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2729670-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2732059-v5-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2732072-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2732500-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2732673-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2732840-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2733955-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2735209-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2736233-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2736422-X86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2736469-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2736782-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2738898-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2739143-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2740180-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2740232-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2741416-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2742185-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2742483-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2742599-X86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2743148-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2743555-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2746119-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2749655-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2750692-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2750841-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2752407-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2753842-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2754704-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2755105-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2755625-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2756198-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2756263-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2756651-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\WINDOWS6.1-KB2756921-X86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2757817-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2760730-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2763342-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2765067-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2765546-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2767652-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2767671-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2768486-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2768492-v3-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2768494-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2768523-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2769121-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2769359-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2769791-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2770660-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2773072-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2775511-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2779272-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2780130-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2780410-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2780444-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2781049-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2782486-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2783429-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2784146-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2784148-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2785220-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2786400-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2786464-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2787046-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2789645-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2790113-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2790804-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2790817-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2791765-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2792026-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2796313-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2796725-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2796764-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2796765-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797120-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797136-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797749-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797789-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797822-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2797918-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2798040-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2798286-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2798670-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2798787-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2799360-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2799406-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2799464-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2799603-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2799925-v2-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2800170-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2800422-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2800789-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2801244-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2801423-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2801453-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2801662-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2803752-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2803759-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2805853-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2807716-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2807986-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2810177-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2814923-x86.msu
C:\WinToolkit141-16\Updates\McRip Windows 7 x86\Windows6.1-KB2821346-v2-x86.msu
C:\IE10\Windows6.1-KB2670838-x86.msu
C:\IE10\Windows6.1-KB2533623-x86.msu
C:\IE10\Windows6.1-KB2729094-v2-x86.msu
C:\IE10\Windows6.1-KB2731771-x86.msu
C:\IE10\Windows6.1-KB2786081-x86.msu
C:\IE10\IE10\z1-IE-Win7.CAB
C:\IE10\IE10\z6-ielangpack-FRA.CAB
#Options
Compatibility Check
Create Backups
Enable CMD
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
Show Duplicates
It seems the workaround is to remove: KB2718695 Microsoft Internet Explorer 10 from: Prerequites Updates, and move to Updates!
Images:
https://skydrive.live.com/?lc=4108#cid=D178EA021B182B88&id=D178EA021B182B88%211532
I think you mean  Wintoolkit 1.4.1.15_Test15,  isn't it?
You can also share your comments on WinCert.net French, if you can't understand or write English:
http://www.wincert.net/forum/forum/154-wincertnet-french/
utiliser WinToolkit 1.4.1.14 je l'ai fait pour windows7 x86 et 64 bits marche nickel pour moi.
merci mooms
Integrate it seperately work with WinToolkit141-22
example : you add updates IE 10 en-us do not use IE LanguagePack after you finish all integrated IE 10 en-us and all update kbxxx etc etc..close wintoolkit and run again ,add update IE LanguagePack
example :
IE10-Windows6.1-LanguagePack-x86-et-ee after you finish integrated IE langpack ..close wintoolkit run again and integrate other LanguagePack
League pack can only integrate one by one :google0dw: :cap:
hi mooms.
ok I apologize if I am guilty
but this is just an example.and this works for all language packs
IE10 ... including IE10 french language packs. :guitar:
But mooms, if his method works to install the French language pack, then that is pertinent to this thread, isn't it?
:P
