Please help with this little problem.
I'm using WinToolkit v1.4.1.21 but this happened an all previous versions.
I keep WinToolkit files on F: partition which is a standard HDD.
When i try to set the Mount folder to my C: partition which is an SSD it won't integrate any updates.
They are all marked in red in the integration process.
When the Mount folder is on the F: partition then and only then it works and all the updates are integrated.
Thanks in advance!
