Posted March 15, 201312 yr My apologies if this is in the wrong section, but there's probably no better place to ask this than in here since we're all obsessed with updates.When it scans for updates, does it ignore the ones you already have installed on your current OS? Is there anyway to turn this feature off or have it scan an ISO instead? (I guess I could always run in it in a VM I guess?).
March 15, 201312 yr Yes, KUC will skip already installed updates (it even knows if its v1 or v2,) it can also scan your offline mounted image and it will also skip updates that cannot be integrated offlineMount your image to a folder and launch KUC with this command-line<program_name>.exe /DVD-Image-dir:<path_to_mount>KUC FAQ
