Posted (edited)
Firstly congatulations to the makers of this program
Im having trouble with creating a fully functional unattended xml file usig Win toolkit
Windows 7 install asks me for a username
Auto login does not commit
See hereunder
Can someone help
<?xml version="1.0" encoding="utf-8"?>
<!--Created by Win Toolkit v1.4.1.22-->
<unattend xmlns="urn:schemas-microsoft-com:unattend">
    <settings pass="windowsPE">
        <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <UserData>
                <AcceptEula>true</AcceptEula>
                <ProductKey>
                    <Key>DELETED</Key>
                <WillShowUI>Always</WillShowUI>
                </ProductKey>
            </UserData>
        </component>
        <component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <UserData>
                <ProductKey>
                    <Key>DELETED</Key>
                </ProductKey>
            </UserData>
        </component>
    </settings>
    <settings pass="specialize">
        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <ProductKey>DELETED</ProductKey>
            <ComputerName>Media</ComputerName>
        </component>
        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        </component>
        <component name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <SkipAutoActivation>true</SkipAutoActivation>
        </component>
        <component name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        </component>
    </settings>
    <settings pass="oobeSystem">
            <Display>
                <ColorDepth>32</ColorDepth>
                <HorizontalResolution>1240</HorizontalResolution>
                <VerticalResolution>768</VerticalResolution>
                <RefreshRate>60</RefreshRate>
            </Display>
            <OOBE>
                <HideEULAPage>true</HideEULAPage>
                <HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE>
                <NetworkLocation>Home</NetworkLocation>
                <ProtectYourPC>3</ProtectYourPC>
            </OOBE>
            <TimeZone>AUS Eastern Standard Time</TimeZone>
        </component>
            <Display>
            </Display>
            <OOBE>
            </OOBE>
        </component>
    </settings>
</unattend>
Edited by ricktendo
Deleted serial
You have to create the user account and then you set that account as the one you want to log into
<AutoLogon>
<Enabled>true</Enabled>
<LogonCount>1</LogonCount>
<Username>YourName</Username>
<Password>
<Value>giberish</Value>
<PlainText>false</PlainText>
</Password>
</AutoLogon>
<UserAccounts>
<LocalAccounts>
<LocalAccount wcm:action="add">
<Description>Desc</Description>
<Group>Administrators</Group>
<Name>YourName</Name>
<Password>
</Password>
</LocalAccount>
</LocalAccounts>
</UserAccounts>
</component>
I've tried this before and had the same problem. Ricktendo, does your suggestion mean that one cannot use the built-in Administrator account and have the unattended.xml actually work, and that one must in fact create another admin account under a different name? I have this problem any time I've used the toolkit to try to use the built-in admin account. It doesn't stick and I end up having to create a user after setup completes.
If one *can* use the built-in admin account in unattended, how do I ensure it will work?
