MBrys331 Posted March 30, 2013 Posted March 30, 2013 how do you add drivers how to convert drivers inf files into Win Toolkit i have no idea how to do this please help please advice what other program do i need for this to happend can you please add convert exe to inf file into Win Toolkit Quote
ricktendo Posted March 30, 2013 Posted March 30, 2013 If your drivers come packaged in a EXE file and you installed them on your current coputer, you will be able to find the extracted drivers you can use with WinToolkit in C:\Windows\System32\DriverStore\FileRepository (sort by date and your drivers will move to the top) Quote
MBrys331 Posted March 30, 2013 Author Posted March 30, 2013 (edited) how do you add the drivers into the install.wim file i have no idea how to do this at all very do not not sure at all to me i located the files and drivers how to add drivers into the build using Win Toolkit thank you for your help Exception:Unknown Error 2: Status: Installing Driver: 1 of (CL_82296.INF) ATI Display Edited March 30, 2013 by MBrys331 Quote
Mr_Smartepants Posted March 31, 2013 Posted March 31, 2013 (edited) ATI/AMD and Nvidia graphics drivers need to be "tweaked" before you can integrate them.DriverPacks.net has already done this for you.Here are the latest beta packs:64-bit: http://forum.driverpacks.net/viewtopic.php?id=661932-bit: http://forum.driverpacks.net/viewtopic.php?id=6612 What OS are you trying to use? AMD CL_*.inf files are only for Vista, CW_*.inf files are only for Win7, and CE_*.inf files are only for Win8. Edited March 31, 2013 by Mr_Smartepants Quote
MBrys331 Posted April 3, 2013 Author Posted April 3, 2013 (edited) i have Windows 7 32-bit trying to learn how to customize windows 7 (Desktop Computer) Video Card: Product Type: GeforceProduct Series: Geforce 500 Series operating System: Windows 7 32 -bit Edited April 3, 2013 by MBrys331 Quote
