ricktendo Posted April 2, 2013 Posted April 2, 2013 Download: http://adf.ly/1713566/lightscribe Size: 8.44 MB MD5: f7ca2696fea2609c4c5b77ffa5b8c9a2 Website: http://www.lightscribe.com Info: Removed old VC runtimes, turned off desktop shortuct, removed website shortcuts and autorun Note: Let me know if you need the installer dialog localized, I can extract the <LCID>.MST from the installshiedl installer so you can apply it Forseti and VandIT 2 Quote
Forseti Posted April 2, 2013 Posted April 2, 2013 works perfectly! great job Ricardo! thank you :thumbsup_anim:Note: Let me know if you need the installer dialog localized, I can extract the <LCID>.MST from the installshiedl installer so you can apply it in german language please ! Thx's Quote
ricktendo Posted April 2, 2013 Author Posted April 2, 2013 I have tried on english system with LS_Update_1.18.27.10_.exe /L 1031 but I CANNOT get the German MST. But you can if you use Universal Extractor on the LS_Update_1.18.27.10_.exe with the "InstallShield /b switch" option on German system you will get the 1031.MST that you can apply with MsiTran.exe To localize your MSI use this commandMsiTran.exe -a 1031.MST LS_Update_1.18.27.10.msi Quote
Forseti Posted September 6, 2015 Posted September 6, 2015 (edited) does not work under Windows 10, HP has set the project! :sad01_anim: @Rick, Is there a trick it under Windows 10 to run to get? Edit: solution is so simple! :dancing: Edited September 6, 2015 by Forseti Quote
