Posted April 8, 201311 yr Hello. How about an option to permanently change the default folder view? I find that when using the Open/Save dialog window, the view does not remain to what you set it to. When using nLite on an XP build, the change does remain intact. I have found a registry hack so the OS will remember the change but would like a more permanent change. Also, during the unattended process, there is an option to select which OS you want installing i.e. Ultimate, Professional, Home Premium, etc... please allow this to be pre-determined when using the Unattended Creator as this is the only option that I need to tick to make a complete Autounattend.xml file. I can still make an Autounattend.xml file but this option I have to select to make the install progress further. Edited April 8, 201311 yr by greyfox
