Posted April 14, 201312 yr FunctionalityMount *.mdx, *.mds/*.mdf, *.iso, *.b5t, *.b6t, *.bwt, *.ccd, *.cdi, *.bin/*.cue, *.ape/*.cue, *.flac/*.cue, *.nrg, *.isz disc images to a virtual driveConvert images from all supported formats to *.mdf/*.mds, *.mdx, *.isoMake .iso, *.mds/*.mdf and *.mdx images of CD, DVD, Blu-ray discsMake a compressed disc image or split the image to several filesProtect images with password Advanced imaging featuresCreate or edit images with powerful Image EditorBurn created images to media discsBurn images with RMPS dataCompose your own images of selected type (CD/DVD disc) with preferred file system (ISO9660+Joliet, UDF)Master bootable discs or imagesManage your Image Collection Media devices virtualizationEmulate up to 32 DT and SCSI devices in allUse 4 virtual IDE devices for advanced emulationMount images to physical IDE/SATA devices via advanced attaching functionalityPerform image mounting to local NTFS foldersGet detailed information about physical and virtual devices' propertiesCustomize virtual drives: change a drive letter, DVD region, etc Advanced user interface with powerful system integrationCustomize user Interface for main application and Image EditorUse powerful Command Line Interface for automation purposesEnable DAEMON Tools integration to Windows shellUse File Associations to mount images right from Windows Explorer or any other file managerCustomize Windows Explorer context menu for images and virtual devicesGet quick access to your Image Catalog via Windows ExplorerPerform basic actions via handy DAEMON Tools Gadget on Windows DesktopDAEMON Tools Pro v5.8.0.0388 (International) Info: Automatically detects and sets the correct language (if supported,) also the follwing options have been DISABLED: Use tray agent, Autostart, Automount, Check for updates, Enable Media Info panel, Send anonymous usage statistics. MD5: 33bebd876d6c27f21c20103822f5643e Size: 11.6 MB Download: http://adf.ly/1713566/dtprowa Website: http://www.daemon-tools.cc SCSI Pass Through Direct a.k.a SPTD v1.86 (x86/x64) Info: Optional, for advanced functions MD5: ac4e5dbe6a2cea68d858fc71e4f8465d Size: 1.07 MB Download: http://adf.ly/1713566/sptdaio Website: http://www.duplexsecure.com Tips: You can customize the settings by extracting the .WA file and editing DTPro.inf. If you want the DAEMON Tools Windows Sidebar gadget installed, extract DT.gadget from the .WA file and integrate it with WinTK.
