Under the Files tab, there is a option to copy/replace files in media root.
There is small problem though, it disregards first folder and throws out an error:
Title: 11 error(s) have occurredErrType: Error (1.4.1.22)Description: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception:Exception:Enable to copy file from 'Z:\Customization\Win7-EFI\boot\bcd' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\bcd' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\bootx64.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\bootx64.efi' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\cdboot.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\cdboot.efi' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\cdboot_noprompt.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\cdboot_noprompt.efi' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\chs_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\chs_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\cht_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\cht_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\efisys.bin' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\efisys.bin' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\efisys_noprompt.bin' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\efisys_noprompt.bin' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\jpn_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\jpn_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\kor_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\kor_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Enable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\wgl4_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\wgl4_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------
Folder efi exists already on media though, but for some strange reason it simply ignores it.
Also it tries to put those on mounted install.wim which is a bit incorrect, those files should go into source folder (media) not into mounted image.
Also could we have an option to copy/replace/add the whole folder, as I had to rebuild USB EFI boot, file by file.
Edited by Etz
Also could we have an option to copy/replace/add the whole folder with contents , as I had to rebuild USB EFI boot, file by file.
Would be also real useful, when building $OEM$ folders to Installation media... :)
Unfortunately not fixed....still same...
v1.4.1.27
Exception:Unable to copy file from 'Z:\Customization\Win-PE-Drivers.txt' to 'D:\W7ToolKit\Mount\D:\Temp\$WinPEDriver$\Win-PE-Drivers.txt' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\bcd' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\bcd' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\bootx64.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\bootx64.efi' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\cdboot.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\cdboot.efi' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\cdboot_noprompt.efi' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\cdboot_noprompt.efi' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\efisys.bin' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\efisys.bin' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\efisys_noprompt.bin' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\efisys_noprompt.bin' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\chs_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\chs_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\cht_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\cht_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\jpn_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\jpn_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\kor_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\kor_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------Unable to copy file from 'Z:\Customization\Win7-EFI\boot\fonts\wgl4_boot.ttf' to 'D:\W7ToolKit\Mount\D:\Temp\efi\boot\fonts\wgl4_boot.ttf' (True)Exception:The given path's format is not supported.----------------------------------
Edited by Etz
