Hi
I finished my custom windows 7 iso. I want to include the setup in a fat32 multiboot usb drive created with ezboot. Now the only problem is that my install.wim file is over 4GB limit. Can the wintoolkit split the image file into 2 parts? Is there another way of doing this?
Many thanks
OK. I just notice the wim split option in win toolkit. Can I just extract my already customized iso file and point wintoolkit to the install.wim? Will this work w/o messing up all the custom changes I made to the setup?
Many thanks
Edited by EB1000
OK. I have split the install.wim into 2 files: install.swm and install2.swm. What do I do with these files? I tried placing both of them inside sources folder instead of install.wim but setup failed with cannot finf install.wim... I guess i have to modify some config files.. but how?
Thanks
