Tweaker Posted May 15, 2013 Posted May 15, 2013 (edited) I always been a fan of this app. SO thanks for working on it :-)\ 1. rebuild image option does not work. It doesn't rebuild the image at all. (what compression are you using?)2.when you remove recovery image from a 64 bit OS wut does not remove both recovery files from syswow64 or system32 folder3.win help core is not removed entirely4.if you run all in one integrator first and remove components like "windows upgrade" the same "windows upgrade" entry is found under "components removal again. (does this mean is not removed properly?)5. vlite option should be available under components removal as well6. speech support and natural language is not removed completely 7. can migration, migration wizard, easy file transfer be added for removal? I hope this help. Edited May 15, 2013 by Tweaker Quote
Kelsenellenelvian Posted May 16, 2013 Posted May 16, 2013 I highly disagree with #5: The way wintoolkit "Removes" components is actually VERY different from vLite's method. Wintoolkit prevents them from being installed to the machine thus eliminating them from the final installation. vLite rips the files completely out and they don't exist at all anymore even on disk... Quote
Legolash2o Posted June 5, 2013 Posted June 5, 2013 I always been a fan of this app. SO thanks for working on it :-)\ 1. rebuild image option does not work. It doesn't rebuild the image at all. (what compression are you using?)2.when you remove recovery image from a 64 bit OS wut does not remove both recovery files from syswow64 or system32 folder3.win help core is not removed entirely4.if you run all in one integrator first and remove components like "windows upgrade" the same "windows upgrade" entry is found under "components removal again. (does this mean is not removed properly?)5. vlite option should be available under components removal as well6. speech support and natural language is not removed completely 7. can migration, migration wizard, easy file transfer be added for removal? I hope this help. 1. Works fine for me, in what way does it not work? Maximum compression.2. Probably both. Not sure, is that something in Component Remover?3. What files are left behind4. I will note this down to look into.5. The methods are completely different.6. What files are left behind? 7. Those sort of requests go here: http://www.wincert.net/forum/topic/10486-removing-components-requests-merged/ Quote
