Hi
I am confused where this topic may fall . in nite or WintoolKit.
i download several addons for Wintoolkit but they wont work becoz they are simple setups and some are zip files which is used in nLite as a Addon , i am wondering how to add nLite addons to WintoolKit ...
Example These cant load into WintoolKit Addon Windows ;
http://www.wincert.net/forum/topic/10539-repack-adobe-reader-xi-1103-en-fr-nl-02-2013/
http://www.wincert.net/forum/topic/9813-tweaked-skype-6332107-multilanguage/
should i unzip those addons , and add that setup and add silent switch ? those .inf file have several withces How i know which Swicth to use... :aggressive:
Those two files are not AddOns, they are repacked installers.
Just add them in the tab silent install+SFX of WinToolkit with the correct switch: "/qn" for Skype and "-gm2 -qn" for Adobe Reader.
"True" (aka inf) nLite AddOns can't be integrated with WinToolkit, they need to be "remade".
If the nlite addon have a svcpack folder with an exe file, most of the time it can be added in the tab silent install+SFX of WinToolkit with a switch if needed (the switch is in the ini file of the addon).
