Posted June 12, 201311 yr Today June 12, 2013 I downloaded the latest updates for Windows 8 Pro (rtm9200)9 updates which were not incorporated by WinToolkit141-27 (latest) also used the "Dism.exe" native Windows where it previously failed to integrate. Please support personnel test the latest updates and fix with a new version of WinToolkite All these updates marked in red were not integrated and even caused error in the copy source that was in my HD http://thumbnails105.imagebam.com/26005/888218260047446.jpg[/url] The same problematic updates were added later in the same silent updates which worked but generated a good delay the completion of the installation errortool.txt dism.log http://www.4shared.com/archive/4hfJUSpv/dism.html Edited June 14, 201311 yr by Flavio Ferreira
June 13, 201311 yr I have the same problem like you. Some updates were not integrated. I hope Legasho will fix this soon.
June 17, 201311 yr Hello, I usually don't post but I haven't be able to integrate the English language pack into my Windows 7 SP1 French installation. I always end up going back to WinToolkit v1.4.1.16 for that matter. I try The Spanish Language pack as well and it works always except for the French one.
June 17, 201311 yr When you try update once by one its work but not for all like KB917607 doesnt work any way..
June 17, 201311 yr Not compatible with SP1 (7601): Windows6.1- KB2533552-x64.msu On my windows 7 pro x64 SP1 im update KB2533552... how its not compatible... bug!
June 17, 201311 yr KB2533552 can't be integrated, it must be installed at first boot (or reverse integration).The same for KB2592687, KB260322, and KB976002
June 19, 201311 yr Author On 6/12/2013 at 11:59 PM, Flavio Ferreira said: Today June 12, 2013 I downloaded the latest updates for Windows 8 Pro (rtm9200)9 updates which were not incorporated by WinToolkit141-27 (latest) also used the "Dism.exe" native Windows where it previously failed to integrate. Please support personnel test the latest updates and fix with a new version of WinToolkite All these updates marked in red were not integrated and even caused error in the copy source that was in my HD http://thumbnails105.imagebam.com/26005/888218260047446.jpg[/url] The same problematic updates were added later in the same silent updates which worked but generated a good delay the completion of the installation aaa.pngerrortool.txt dism.log http://www.4shared.com/archive/4hfJUSpv/dism.htmlUsing an older version got the following results:http://www.imagebam.com/image/166229261150961
