Hello lego btw thanks for update :thumbsup:
i'm report this BUGS...
screensoot :
I don't know which updates the non integratable to the offline image ,because it's wintoolkit not move to silent install ... Unlike KB2533552 KB2592687 KB2603229 update on windows 7 :doh:
2013-06-13_22-27-58.ini
Edited by Ctrl
Hello Lego :D I've got the same problem with 16 updates in Windows 8 Pro x64. "Win Toolkit has recorded Errors which occurred during integration and have been stored via "  :confused02:  KB2822241, KB2823233, KB2823516, KB2829254, KB2830290, KB2833510, KB2836187, KB2836988, KB2838727, KB2839894, KB2845533, KB2845690, KB2847928, KB2850674, KB2853915, KB2856758. But anyway, Keep up the good work  :thumbsup_anim:
+1
Hi, this is my first post, and I want to report that I've got the same error. But, as seen in the below screenshot, the error is only from 3 updates: KB2856758, KB2853915 and KB2838727
post-47701-0-38719700-1371427798_thumb.p
Exception:An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.2.9200](c) 2012 Microsoft Corporation. All rights reserved.D:\Program Files\WinToolkit>Set SEE_MASK_NOZONECHECKS=1D:\Program Files\WinToolkit>"C:\Windows\System32\Dism.exe"  /Image:"F:\Win8" /Add-Package /PackagePath:"E:\Software\OSs\Win8 Updates\CAB\Windows8-RT-KB2856758-x64.cab" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.2.9200.16384Image Version: 6.2.9200.16384Processing 1 of 1 - An error occurred - Package_for_KB2856758 Error: 0x800f082fError: 0x800f082fDISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Program Files\WinToolkit>exit----------------------------------An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.2.9200](c) 2012 Microsoft Corporation. All rights reserved.D:\Program Files\WinToolkit>Set SEE_MASK_NOZONECHECKS=1D:\Program Files\WinToolkit>"C:\Windows\System32\Dism.exe"  /Image:"F:\Win8" /Add-Package /PackagePath:"E:\Software\OSs\Win8 Updates\CAB\Windows8-RT-KB2853915-x64.cab" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.2.9200.16384Image Version: 6.2.9200.16384Processing 1 of 1 - An error occurred - Package_for_KB2853915 Error: 0x800f082fError: 0x800f082fDISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Program Files\WinToolkit>exit----------------------------------An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.2.9200](c) 2012 Microsoft Corporation. All rights reserved.D:\Program Files\WinToolkit>Set SEE_MASK_NOZONECHECKS=1D:\Program Files\WinToolkit>"C:\Windows\System32\Dism.exe"  /Image:"F:\Win8" /Add-Package /PackagePath:"E:\Software\OSs\Win8 Updates\CAB\Windows8-RT-KB2838727-x64.cab" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.2.9200.16384Image Version: 6.2.9200.16384Processing 1 of 1 - An error occurred - Package_for_KB2838727 Error: 0x800f082fError: 0x800f082fDISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Program Files\WinToolkit>exit----------------------------------
2013-06-16_21-12-58.ini
Edited by Cosmik
  • 4 weeks later...
Hi Ctrl,
Try to correct the path, leaving no spaces in the names, this may fix the problem.
Your path: E:\OS-\HOTFIX_W8_apr_2013\NEW X86\Windows6.2-KB2779444-x86.msu
Path adjusted: E:\OS-\HOTFIX_W8_apr_2013\NEWX86\Windows6.2-KB2779444-x86.msu
Hi xspeed_one,
Having this very integration problem I tried your suggestion to no avail. I've tried only security updates, non-security updates, exclude .Net updates, include .Net updates. I've tried multiple iterations of integration and it always fails on Windows 8.
