Hello guys just a fast question. I was just wondering what in your opinion is better method of updating the windows 7 install iso. Using the sysprep(installing windows, updating it etc, then making an image) or integrating the updates offline using lets say WinTolkit? Mainly i ask this because i wanna know if there will be any difference in the final result in terms of speed, size and quality of the Windows installation iso. Till now i was always using the sysprep method as it seems easyer to do(I install FrameWork, Visual C runtimes etc). But I'm wondering if I integrate the updates offline will i get better performance of my install? Thanks.
