https://www.sumatrapdfreader.org/free-pdf-reader.html
- Original installers repacked to made them silent
- SumatraPDF will be installed in %ProgramFiles%.
- The Dual version automatically install the version corresponding to your architecture (x86 or x64)
- Compatible from Vista to 11, 32/64 bits
- Multilingual
- PDF format associated to SumatraPDF (only on Windows 7 & below)
- Uninstallable
Starting from version 3.4.1, you can use the -ai switch on the sfx to let Windows Search index the content of your PDF.
 SFX_SumatraPDF_3.5.2_Dual.exe
 SFX_SumatraPDF_3.5.2_x64.exe
 SFX_SumatraPDF_3.5.2_x86.exe
Last version compatible with Windows XP:
SFX_SumatraPDF_3.1.2-Dual.exe
MD5: a5b039b61347f4dc383c78fb9715164a
  • 3 months later...
Changes in this release:
    full-screen mode for ebooks (Ctrl-L)
    new key bindings:
        F9 - show/hide menu (not remembered after quitting)
        F8 - show/hide toolbar
    support WebP images (standalone and in comic books)
    support for RAR5 compressed comic books
    fixed multiple crashes
  • 7 months later...
  • 2 page view for ebooks
  • new keybindings:
    • Ctrl+PgDn, Ctrl+Right : go to next page
    • Ctrl+PgUp, Ctrl+Left : go to previous page
  • 10x faster ebook layout
  • support JP2 images
  • new advanced settings: ShowMenuBar, ReloadModifiedDocuments, CustomScreenDPI
  • left/right clicking no longer changes pages in fullscreen mode (use Presentation mode if you rely on this feature)
  • fixed multiple crashes and made multiple minor improvements
2.5.1 (2014-05-07)
  • hopefully fix frequent ebook crashes
thanks a lot it will be cool to associate with chm too ciao
Not possible with the stock installer. Can be done with a reg file launched by the SFX.
  • 5 months later...
Updated to v3.0 and added a switch to install plugins.
3.0 (2014-10-18)
  • Tabs! Enabled by default. Use Settings/Options... menu to go back to the old UI
  • support table of contents and links in ebook UI
  • add support for PalmDoc ebooks
  • add support for displaying CB7 and CBT comic books (in addition to CBZ and CBR)
  • add support for LZMA and PPMd compression in CBZ comic books
  • allow saving Comic Book files as PDF
  • swapped keybindings:
    • F11 : Fullscreen mode (still also Ctrl+Shift+L)
    • F5 : Presentation mode (also Shift+F11, still also Ctrl+L)
  • added a document measurement UI. Press 'm' to start. Keep pressing 'm' to change measurement units
  • new advanced settings: FullPathInTitle, UseSysColors (no longer exposed through the Options dialog), UseTabs
  • replaced non-free UnRAR with a free RAR extraction library. If some CBR files fail to open for you, download unrar.dll from http://www.rarlab.com/rar_add.htmand place it alongside SumatraPDF.exe
  • deprecated browser plugin. We keep it if was installed in earlier version
  • 11 months later...
Updated to v3.1, now the SFX will automatically install the build depending on the OS (x86 or x64).
3.1 (2015-10-24)
  • 64bit builds
  • all documents are restored at startup if a window with multiple tabs is closed (or if closing happened through File -> Exit); this can be disabled through the RestoreSession advanced setting
  • printing happens (again) always as image which leads to more reliable results at the cost of requiring more printer memory; the "Print as Image" advanced printing option has been removed
  • scrolling with touchpad (e.g. on Surface Pro) now works
  • many crash and other bug fixes
Updated to v3.1.1
3.1.1 (2015-11-02)
  • (re)add support for old processors that don’t have SSE2
  • support newer versions of unrar.dll
  • allow keeping browser plugin if it’s already installed
  • crash fixes
Quote
3.1.2 (2016-08-14)
    fixed issue with icons being purple in latest Windows 10 update
    tell Windows 10 that SumatraPDF can open supported file types
  • 3 years later...
  • mooms changed the title to SumatraPDF 3.1.2 & 3.3.3
On 1/8/2022 at 10:46 PM, mooms said:
First post updated with latest release (3.3.3) and version 3.1.2 restored.
please also upload version 3.2   x64 bit and x32 bit
I see, but I will not re-create an outdated installer just for you.
Maybe someone have kept it ?
Or just use switches to make the installer silent:
SumatraPDFinstaller.exe -install /s /d "%ProgramFiles%\SumatraPDF"
  • 5 weeks later...
plz if you have time make a repack for Sumatra PDF version 3.2 x32bit
  • mooms changed the title to SumatraPDF 3.1.2 & 3.4.1
Version 3.4.1
Changelog for SumatraPDF:
Quote
3.4.1 (2022-05-25)
  • fix downloading of symbols for better crash reports
3.4 (2022-05-24)
  • Command Palette
  • customizable keyboard shortcuts
  • better support for epub files using mupdf's epub engine. Adds text selection and search in ebook files
  • search / translate selected text with web services
  • installer: -all-users cmd-line arg for system-wide install
  • added Annotations.TextIconColor and TextIconType advanced settings
  • added Annotations.UnderlineColor advanced setting
  • added Annotations.DefaultAuthor advanced setting
  • i keyboard shortcuts inverts document colors Shift + i does what i used to do i.e. show page number
  • u and Shift + u keyboard shortcuts adds underline annotation for currently selected text
  • Delete / Backspace keyboard shortcuts delete an annotation under mouse cursor
  • support .svg files
  • faster scrolling with mouse wheel when cursor over scrollbar
  • add -search cmd-line option and [Search("<file>", "<search-term>")] DDE command
  • a way to get list of used fonts in properties window
  • support opening .heic image files (if Windows heic codec is installed)
  • add experimental smooth scrolling (enabled with SmoothScroll advanced setting)
Quote
3.4.2 (2022-05-27)
  • make keyboard accelerators work when tree view has focus
  • fix -set-color-range and -bg-color replacing MainWindowBackground
  • fix crash with incorrectly defined selection handlers
  • mooms changed the title to SumatraPDF 3.1.2 & 3.4.3
Quote
3.4.3 (2022-05-29)
  • re-enable Backspace in edit field
  • fix installation for all users when using custom installation directory
  • re-enable Copy Image context menu for comic book files
  • fix display of some PDF images
  • fix slow loading of some ePub files
  • mooms changed the title to SumatraPDF 3.1.2 & 3.4.4
  • mooms changed the title to SumatraPDF 3.1.2 & 3.4.5
  • mooms changed the title to SumatraPDF 3.1.2 & 3.4.6
