Hello,
In Advanced, Files I add files to %SystemDrive%\Installation perfectly
but is it possible to add Folders ?
:g:
Nope, not through that Wintoolkit feature. If you want a simple solution, there isn't one. Best suggestion - make a silent addon via a .7z installer that includes that folder and a simple .batch files that has admin privileges.
That's true if you use Wintoolkit, how about just using an $oem$ folder? No need to make this complicated, create folder called $oem$ within that folder create another called $1 and put what ever files or folders you need on your %SystemDrive% in it, put the $oem$ folder in your Win 7 sources folder, that's it.
