I just wanted to say, if it was possible, is it possible to change a x32 OS to x64, and visa versa. I took me forever to find a well working Dell Windows 7 for my sister, but it's only x32 bit, and it would be extremely helpful. and i made a x64 OS that takes 2 hours to complete other than the usual 1 hour, and I really want to make a x32, but i didn't save a preset.  SO, if this CAN save time, can you please add this?
I'm not sure exactly what you are asking, but if you are asking if it is possible to "upgrade" an existing x32/x64 installation to the other architecture, I don't believe that is possible.
yeah, that was exactly what i meant, but only the x32, i think i heard a while back there was a way to do it with xp, but, oh well, thanks for responding :)
