Posted July 3, 201311 yr Hi there, I've found a lot of add-on packages and tranform packages for MCE, but what I want is Media Center EXE or MSI installer which can be able to install mce on every Windows NT 5.1 (xp, server 2003, x64, xp betas). My idea comes from this topic needed files:medctroc.inf file and mediactr.cab command:rundll32 syssetup,SetupInfObjectInstallAction Freestyle 128 medctroc.inf but I don't want to search for mediactr.cab, I want to fully automated this process. last action is tweak nt to convert edition to mce - I think this can be manage with registry setting. Is not really metter how gonna be batch, exe, msi installer, I just want to be automated and if possible to be updated to last version 3011.
July 3, 201311 yr Put the INF in a \cmpnents\mediactr\i386 sub folder or edit the [sourceDisksNames] in medctroc.inf to remove that sub dir and just put all files in the same dir
July 3, 201311 yr Author Put the INF in a \cmpnents\mediactr\i386 sub folder or edit the [sourceDisksNames] in medctroc.inf to remove that sub dir and just put all files in the same dir How exactly to edit [sourceDisksNames] in medctroc.inf?Should I delete whole row or something else? Also for example I want to run install.bat from any local path (temp, cd, etc), and can you tell me how should be the structure in the folder folder: MCEforNT51file 1: mediactr.cab (is it possible to include October 2006 update ?) file2: medctroc.inf row n: [sourceDisksNames] row n+1: --- blank --- file 3: install.bat rundll32 syssetup,SetupInfObjectInstallAction Freestyle 128 medctroc.inf
July 3, 201311 yr Just the subdir, should end up like this[SourceDisksNames]1=%cd2name%, "mediactr.cab", ,You want a updated media center including update rollup 2 and updates use my MCE 2005 addon
August 9, 201311 yr Author I cannot find how TweakNT convert Windows SKU from PRO to MCE and vise-versa from loaded windows thought only one reboot, to do my self...
