Posted July 6, 201311 yr Hi all. I was wondering about using Win ToolKit and the ADK/WAIK together.I'm liking what WinToolKit offers, and if I need any additional tweaks I can use a .cmd and registry lines,but the unattended options are not enough for me. From what I see after using the unattended wizard in WinToolKit is that it does changes to the files the same way WAIK does,so I was wondering can I use WTK for the most part and WAIK for the options I'm missing? or maybe it's best to use WAIK 1st and WTK 2nd?
July 6, 201311 yr My autounattend.xml was generated by WTK at the beginning, then I begun to use WAIK on the same file: no problem at all. Thiersee
July 8, 201311 yr I have had the same experience... I have added so much to my xml since it was 1st generated and I am still learning/experimenting with this. My autounattend.xml was generated by WTK at the beginning, then I begun to use WAIK on the same file: no problem at all. Thiersee
