Posted July 8, 201311 yr I have spent all weekend testing and updating my integration process and KB2823180 doesn't want to play nice at all... I integrate McRip's updates in STEP-1 STEP-1-UPDATES-07-07-13.ini and then I integrate my SFX items which includes KB2823180 (after .NET 4.5) STEP-2-SFX-07-06-13.ini and it always shows in MS Update.... even the KUC shows it uninstalled YET Windows update history shows it installed... has me stumped.
July 13, 201311 yr I answered here. But this info was already available both here at wincert forums and also at the MDL hotfix repository. Use the search funtion more often.
July 13, 201311 yr Author Rica, I would think that you would know that I really did use the search or I wouldn't have asked the question... I'm not a newbie here :doh: ...I am just not finding a clear answer to my question so I may have missed it... but my SFX .ini shows that it is installed after .net and it's the last framework hotfix installed. Does WinToolKit change the order of the fixes (other than the pre-req's)? Thanks for your help I always appreciate it. I have spent all weekend testing and updating my integration process and KB2823180 doesn't want to play nice at all... I integrate McRip's updates in STEP-1 STEP-1-UPDATES-07-07-13.ini and then I integrate my SFX items which includes KB2823180 (after .NET 4.5) STEP-2-SFX-07-06-13.ini and it always shows in MS Update.... even the KUC shows it uninstalled YET Windows update history shows it installed... has me stumped.
July 13, 201311 yr I'm pretty sure it's alphabetical order for installers during RunOnce (I always used a number of''z'' letters in front of the ones I needed to be installed in a special order / lastly).
July 13, 201311 yr Author Thanks I am setting up a new set as I write this and testing it with the zzz trick thanksI'm pretty sure it's alphabetical order for installers during RunOnce (I always used a number of''z'' letters in front of the ones I needed to be installed in a special order / lastly). Edited July 13, 201311 yr by compstuff
July 14, 201311 yr Author OK so a brand new integration using KB2823180 installed after ,Net as a SFX with a z in front to make sure it is installed last... it shows up in MS Update and it also shows up as installed when I check installed updates. Edited July 14, 201311 yr by compstuff
July 14, 201311 yr Author More: I used the KUC script update_ldr command to add KB2823180 as an LDR and it still shows up... then I ran it as GDR and LDR with his script and it still showed up... this is weird
July 15, 201311 yr I'm pretty sure it's alphabetical order for installers during RunOnce (I always used a number of''z'' letters in front of the ones I needed to be installed in a special order / lastly). Thanks I am setting up a new set as I write this and testing it with the zzz trick thanksI'm pretty sure it's alphabetical order for installers during RunOnce (I always used a number of''z'' letters in front of the ones I needed to be installed in a special order / lastly). There is no need to rename your files, wintoolkit add the "00# " (3 digits and a space before the name of the file in the windows registry) to have it installed in the order you set while integrating.
