Posted July 10, 201311 yr Hi.I tried a few apps for virtual machines and I keep getting the same error when the windows installation is supposed to start: it says the pc is not 64 bit compatible(I'm running the 64 virtual machine software on a 64 win7).
July 10, 201311 yr What virtualization software have you tried ? You must have missed an option.Your CPU must have some options also, can be enabled/disabled in the BIOS.Try VirtualBox, at the VM creation you can choose wich OS you will install and it will configure the VM according.
