Posted July 28, 201311 yr Hello everyone. First of all, I'd like to thank all of the members of this great forum community, because I've been abe to accomplish mostly everything that I've wanted to using all the topics and tutorials available on this forum. Unfortunately for me, there are two updates that I cannot seem to integrate to my Windows XP x86 SP3 DVD using nLite. The two updates are KB2798897 and KB2846071. Let's first start with KB2846071. I tried adding this hotfix in the normal way using nLite. I simply added the file WindowsXP-KB2846071-x86-FRA.exe from Microsoft download center at the hotfix page. nLite took it and I didn't got any error. (FRA, beccause my Windows is in French language) But after installing Windows, this update pops in the Windows Update results, which means it didn't got integrated correctly to the installation disc. I then tried integrating it using the Nonno Fabio & OnePiece Addon Creator. I tried two different way. The first one was to simple create it as an UpdatePack. While integrating, nLite poped an error H- related to the lenght parameters.Then I tried another method with the Nonno Fabio & OnePiece Addon Creator. I selected Internet Explorer 8 instead of UpdatePack. Thus created a TrueAddon containing only thins update. When I added this TrueAddon to nlite, I didn,t get any error, so I was quite confident it had worked. Well no, it didn't, once Windows was installed, I still had this KB2846071 poping up in the WindowsUpdate results. Now to the second update causing headaches; KB2798897. I tried at first to integrate this file normally using nLite at the hotfix page by adding the rvkroots.exe file from Microsoft download center. It didn't work, nLite said that it wasn't a compatible file or something like that. Then I have googled around and ended up on this forum on the folowwing thread: http://www.wincert.net/forum/topic/9984-repak-kb2798897-revoked-root-certificate/ The suggestion is to rename rvkroots.exe to rootsupt.exe so that nLite recognise it. nLite did recognise it and integration went well. Well, at least it didn't pop any error. But after installing Windows, KB2798897 showed up in the Windows Update results. So I had failed again! In the same topic, on post #3, user ricktendo posted a AIO pack of the update. I went ahead and tried it by renaming the file rootsaio.exe to rootsupt.exe so that nLite recognize it. nLite took it without any problem again. But once Windows installed, here I had this KB2798897 poping up again in the Windows Update results. So this is all I've tried so far (and all I can think of). Any help would be much appreciated. My Windows XP Post SP3 disc is all updated, only these two updates won't integrate and I can't seem to know why. I managed to integrate all the dotNET, IE8 and MP11 without much troubles, but these two updates are a pain in the **.Thanks in advance,Phil
July 28, 201311 yr nLite can integrate IE but it will fail if you try to integrate the cumulative update why WU is prompting for rvkroots is a mystery to me
July 28, 201311 yr @GuizmoPhil: Wincert have a French section, and you can find an update pack monthly updated by icare for French XPSP3 that you should try.
July 30, 201311 yr Do I integration into my XP SP3 with HFSLIP. These hotfix are integrated without problems. If you are interested, see these links: http://www.msfn.org/board/topic/140336-the-file-checker-hfslipfc-for-hfslip/ http://mimo.zxq.net/updatelist.htm http://www.msfn.org/board/topic/163230-new-hfslip-beta/
July 30, 201311 yr Author Thanks everyone for the suggestions and information. I'll have a look at all the links you've provided.
