Hi compstuff
Just have seen your tweaks and, as i don't have an account in MDL & don't think it is necessary just to give you these tips:
Where the tweaks doesn't works, use yes instead of true and use no instead of false if you pay attention, BlockPopups uses yes and works.
If yes doesn't works, EnableLinksBar could be EnableFavoritesBar
In Help_Page could works any web page
Interesting thought... I used the WIM Manager for my XML and the true/false were the only options but I could try to a manual edit and see what happens... the blank entry in help page is the default for the MS website... thanks for the response and I will report back
