Hi Experts,
I got a problem with the new Socket1150, 8th Chipset Family;
The USB ports (2.0 and 3.0), the USB Header and also ATX iO Shield ain't functional when Windows is started.
Win7 was installed from a WDS Server: I tried to fix the problem with an adding of new Drivers in WDS 'Driver Group 1 Folder'
I added and tested Drivers:
Renesas µPD720200 & µPD720200A
Newest Native Driver by Intel xHCI (8 Series/C220 Chipset Family)
... but none was functional.
I have already thought about not taking the USB Drivers into the 'Driver Group 1 Folder' on WDS, but implementing in Win7 Image (*.wim).
Has somebody already tried that out?
Thanks ahead!
Dear ricktendo,
thanks for quick reply, i try on three diffrent Mainboards, here @ work we have lots of different models.
Newest C2 Stepping, too.
Installation from DVD or USB works fine, deploy by WDS issues i tell you above.
