Dice que no va a actualizar a vLite pero suena que tiene otro proyecto en mente para Win7/8
For now there is no plan to update vLite, I am working on something else which will cover that area. The release date is not yet known, it is safe to say it can be counted in months, not years.
hay nueva versión de n-lite...v1.4.9.2
  • upd: Deeper file version inspection during integration comparison
  • upd: Direct integration support for many more hotfixes, mainly XP (including x64)
  • upd: 'entries.ini' as a single-file update pack support
  • fix: Internet Explorer 8 direct integration (including x64)
  • fix: 'entries' in an update pack path was not allowed
DESCARGA OFICIAL
http://nliteos.pcrpg.org/nlite/nLite-1.4.9.2.setup.exe
hay nueva versión: v1.4.9.3
  • upd: 7z.exe to 9.20
  • upd: Added a warning if ISO creation was skipped
  • upd: Added a warning about KB2686509 compatibility with tweaks and removals
  • fix: OEM Branding option caused a generic error occured in gdi+
  • fix: Direct KB975254 integration for XP Pro
  • upd: Brazilian Portuguese translation
DESCARGA:
http://www.nliteos.com/download.html
  • 3 months later...
  • 4 weeks later...
