Posted August 17, 201311 yr I tested only with updates and any updates are causing the problem. which update is the one that gives the error? --------------------------- He probado solo con actualizaciones y alguna de las actualizaciones están causando el problema. qué actualización es la que dá el error? 1 error.- Second Error.- Error Number Three.- I dont know what update is the problem...... Edited August 18, 201311 yr by latino
August 17, 201311 yr Sorry, no problems at all integrating a german IE10 in a german Win7 or italian IE10 in an italian Win7! RegardsThiersee
August 18, 201311 yr Author Sorry, no problems at all integrating a german IE10 in a german Win7 or italian IE10 in an italian Win7! RegardsThiersee Hello.... Hi, I tested with other updates and I continue to present the same mistake ... Now I joined the Internet explorer only 10 and everything is perfect. Now I've been testing between updates and really do not know what to do ..... I do not know how to test more. hola, he probado con otras actualizaciones y me continúa presentando el mismo error... Ahora solo integré el Internet explorer 10 y todo está perfecto. Ahora he estado probando entre actualizaciones y realmente ya no sé que hacer..... Ya no sé como probar más.
