illeach1 Posted September 25, 2013 Posted September 25, 2013 Hi, I'm using WinToolkit (Awesome piece of software) to deploy My Windows 7 Disk, but I have few questions I couldn't find answer (or understand) them.. First if I integrate my silent installers. they will be installed automatic or manual after Win installs right? but what if I need to update applications time to time should I mess every time with AIO? I mean if i need to update let's say K-lite I wlways have to open the image in WTK AIo or is there any other way, or wpi? so I can be able to add extra applications without messing with Wimsecond it's off topic but after 100's of hour research i couldn't find actual answer that is SP1 error free? I know it's updated version with lots of post updates but I heard people talking against it, I tried it in one of my pc and I had BSOD System Exception Errors few times but I tired bsod viewer and according to given results given by BSOD Viewer it was graphic card driver problem, I updated it by NVidia latest driver and at the moment didn't get any BSOD yet.. I have to install Win to many pc's so what are the recommendations about SP1? 3rd what about .NetFX should I integrate or silent install it? thanks Quote
Kelsenellenelvian Posted September 26, 2013 Posted September 26, 2013 I would go wpi. Its easier to mantain. Quote
ricktendo Posted September 26, 2013 Posted September 26, 2013 You can also do allot of cool stuff (if you know how to) to make WPI a smart installer, it can detect if your program is already installed and it will grey it our if it is Quote
bphlpt Posted September 27, 2013 Posted September 27, 2013 And yes, you should use SP1, but there have also been hundreds of updates since SP1 as well. Cheers and Regards Quote
illeach1 Posted September 27, 2013 Author Posted September 27, 2013 thank you guys now I get the idea. Quote
