Posted October 1, 201311 yr Hey Leogolash2o, Well Windows 8 Tweak Enable Legacy .Net Framework is not working with 8.1. I just want to bring it your notice. I request any moderator to move this thread to appropriate place regardsMack Edited October 1, 201311 yr by macky_reddy
October 6, 201311 yr Unfortunately it doesnt work for RTM version or for 8.1, but... You can use unattended.xml instead... (Dont forget to adjust version number) <servicing> <package action="configure"> <assemblyIdentity name="Microsoft-Windows-Foundation-Package" version="6.2.8250.0" language="neutral" processorArchitecture="AMD64" publicKeyToken="31bf3856ad364e35" versionScope="nonSxS" /> <selection name="NetFx3" state="True" /> </package></servicing>or Dismdism.exe /online /enable-feature /featurename:NetFX3 /All /Source:E:\sources\sxs /LimitAccessI personally Use Unattended.xml method as I enable lot of packages, which are disabled (not installed) by default, for example: telnet client, snmp, netfx3, etc, etc... Edited October 6, 201311 yr by Etz
November 1, 201311 yr Hi. I made a unattedned.xml and paste this code to it. but don't enable .Net 3.5 after Installing Windows 8.1. https://www.dropbox.com/s/drgmawwwplsorpk/unattended.xml Please Guide Me. Edited November 1, 201311 yr by Behdadsoft
November 1, 201311 yr I`am currently using SetupComplete.cmd file for that... And doing it via Dism method, with same commandline as showed in previous post.
November 2, 201311 yr I`am currently using SetupComplete.cmd file for that...I'am put unattended.xml to dvd root. or must run it with SetupComplete.cmd?? And doing it via Dism method, with same commandline as showed in previous post. I want Integrated Installing Windows .Net3.5 is enabled.
