Posted October 20, 201311 yr when i copy anything to my pen drive it shows a shortcut of that inside my pen drive.While the size of used space and free space according to size of content inside the pen drive.if i create a new folder inside then it is also created as a shortcut of new folder.Now if i paste anything inside the new folder inside the pendrive it do not create the shortcut its remains same as the original content.Please help
January 25, 201411 yr Author i got its solution.Re install the window using the same pen drive by using a software winsetupfromusb.After the installation of window format pen drive. And now copy again any file to pen drive no shortcut of that file occure.@keira it is not fine if you use that shortcut creating pen drive to another computer then it is also effected from that virus and it again effect any healthy pendrive.The other thing is that the shortcuts are shortcuts never works on another computerso thumbs down for your answer.
March 17, 20168 yr 23 hours ago, mooms said: What ?? it is a name of malware detected by Quhioo360. it make some nasty shorcut on usb drives also spread via autorun.inf
