  • Replies 125
  • Views 52.4k
  • Update: Updated 7za and the sfx module. The setups are no longer renamed, the config file is now dynamically generated. The Binary folder has been renamed to setup, so it's clearer
  • Version 3.1 Updated 7za to version 1805. Updated the icon of the sfx module from WinRAR 5.60. Added a theme in the Themes folder (the previous default theme of WinRAR). If
  • You're welcome alfreire.   ____________   V2.2 of the maker: added the possibility to import a reg file with customs prefs (thanks to alfreire for the idea).
7 hours ago, bundy-al said:
How must i launch it manually with -ai switch ?
From the command line, or create a shortcut and add the -ai switch.
6 hours ago, bundy-al said:
May i have your SFX.exe for testing.
And the script line you have used to install with a new windows 10 installation.
No sorry, I can't share it as it's registered with a key.
I don't use any script for that, with Windows 7 I have used WinToolkit Runonce.
Mooms can you tell me how to put the SFX_winrar in the WinToolkit_1.7.0.15.
Step by step, to see if that will work.
Regards
mooms maybe I'm not doing it right.
I now have these files.
SFX_WinRAR_x64_6.01-nl.exe
WinRAR_AddOn_x64_6.01-nl.zip (do i need to unzip this folder ?)
And what should I have started in my setupcomplete.cmd?
I have this line in it now,
IF EXIST "%SLocal%\SFX_WinRAR_x64_6.01-nl.exe" "%SLocal%\SFX_WinRAR_x64_6.01-nl.exe"
Should I place the WinRAR_AddOn_x64_6.01-nl.zip along with SFX_WinRAR_x64_6.01-nl.exe in my Windows 10 ISO
You can discard the zip, it was just created to be used wit nLite, but the exe inside is the same as the one created outside (you can compare the files).
If you use wintoolkit runonce as advised, the exe will be copied in the wim file by Wintoolkit, so you don't need it anywhere else.
I don't use setupcomplete so I can't provide any support on it.
mooms I did what you said, made the winrar + Themes an .exe of it and added it to WinToolkit and had a Windows 10 .ISO created.
It now installs perfectly.
Thank you for your support.
Regards
  • mooms changed the title to WinRAR SFX Maker 3.2
  • 5 months later...
  • 1 year later...
  • 1 year later...
  • mooms changed the title to WinRAR SFX Maker 3.3
