WinRAR SFX Maker 3.4
  • Replies 126
  • Views 80.5k
  • Update: Updated 7za and the sfx module. The setups are no longer renamed, the config file is now dynamically generated. The Binary folder has been renamed to setup, so it's clearer
  • Version 3.1 Updated 7za to version 1805. Updated the icon of the sfx module from WinRAR 5.60. Added a theme in the Themes folder (the previous default theme of WinRAR). If
  • You're welcome alfreire.   ____________   V2.2 of the maker: added the possibility to import a reg file with customs prefs (thanks to alfreire for the idea).
its work=everything what you did is ok....give me a link to share sfx in our beatufull site and I will do it.By the way what you mean :Maybe your AV is blocking the file.....never had such a problem before????Just stop defender and try again?????
I tried by stoping Defender, Mooms but the result was the same-real suprice-I never got any problem with sfxmakers-I got winrar and mozzila.Mozzial is ok,but winrar still show me the same message.By the way is any chance to see maker for waterfox for different languages???Or only with availible packs?Thanks Mooos-you are the best global mod dude!Keep going!
I have no idea dude-you are rigth but everything is in the rigth place before starting cretaion of silent instaler.Im totaly confused,never had such a problem......damn-no explanation for me!
I understand
Your opinion was important to me!
I am the administrator of the entire  my operating system. What we suspected was related probably to the anti-virus, Defender may be the cause.
The fact that on your machine everything works without a problem force me to dig into the basics of my system to track which of my modifications caused problems. I always manually modify the OS in advance,before preinstal, remove unnecessary ones, add my own extras and other developments.
Thank you for your time. I wish you to continue to make your developments so successful - I think they are important for all users.Keep going dude!
Sincerely yours Stanislaw Majcherczyk!!!
I've made a new version of the script, rewritten from scratch.
  • No more 7zip SFX, instead the WinRAR installer is updated with WinRAR (WinRAR must be installed).
  • No need to uncompress the themes, the script will do it for you.
  • Dropped support for multi arch, as WinRAR will only be 64 bits starting with 7.10 anyways.
  • Dropped support for nLite/RVMi addon cration, not needed anymore.
  • This script should work with any version of WinRAR.
  • I had to include RAR Unlocker as the WinRAR installers are often locked.
And still:
  • support for rarreg.key
  • support for adding custom registry keys.
Read the included readme.txt for more information.
The script should not trigger any false positives from AV, but the created installer could be blocked by your AV, if it's the case, add it to the exclusions (or pause real-time protection before running it).
For now it's considered beta, and I will keep v3.3 in the front page.
Please test it and report if it works for you.
WinRAR_SFX_Maker_4.0.zip
And still:
Dear dude-for now one-the situation is still the same,i notice in my computer RarUnlocker doesnt recognize winrar.exe file-I tested new beta 4.0 but its hard for me to be the correct reporter with a good news for you.My PC is still quite a mess bro.I noticed just one think,after clean reinstal the whole OS at this moment Im on 4534(23H2)-before first restar after all updates and blaaa,bla  the script and winrar silent maker works correct,but then...cmd ,shell everything just freeze.Cheers bro!
Rar Unlocker is only needed if the archive is locked. You can launch it, it have a GUI.
I don't know what is the problem with your Windows install, maybe you should try to install a version without any modifications.
You can also try to run the maker in a virtual machine if you're familiar with.
  • mooms changed the title to WinRAR SFX Maker 3.4
