Hi volks,
does anybody have an SFX-Installer (silent) for DirectX Redist June 2010?
McRip is at the moment not active and his SystemFile-Installer is not updated.
TNX
Thiersee
Nope. You can get it from here.
Note - it's not the original ricktendo file, I don't have it. I repacked it to make it silent, but that probably helps you :)
Thanks, RN!
I'll try it.
Thiersee
Thanks both of you!
Only one question, the most important:
do I need DirectX 9 (June 2010, even if Windows 7 has DirectX 11 built in?
How can I proof, that DirectX 9 is properly installed (dxdiag says,of course, I have 11).
Thiersee
Well now I am thinking the same thing since I don't play any games at all  :doh:
Old games need DirectX9.
Only old games?
In this case I don't need it, I play only Tetris and Flipper :D.
Thiersee
DXCB can also make an UN-installer that can completely remove DirectX9 from your system, no matter from what OS, XP and later, no matter what language your OS is, and no matter how DirectX9 was installed. :)  I never knew why MS never bothered to do so.  The installers made via DXCB are the smallest ones I know of, and can be made to fit your system's requirements, 32bit only, 32bit plus 64bit for 64bit systems, optional DirectX for managed code, etc.  Addons can be made for use by RVMi or nLite on XP, and the switchless installers can be applied to a running system with no problem.
[/shameless plug]
