READ THE FIRST PARAGRAPH CLOSELY!
My next release is going to be public also but the last supporter release could stand some more testing too. PLEASE test this out as fully as you can so I can make a good stable release. My birthday is Dec 8th and I am going to shoot for WPI 8.7 release on that day!
ALSO PLEASE DONATE IF YOU CAN!!!
The file can be gotten from www.wpiw.net! All download links are to 8.6.7
Change-log for 8.6.7
v8.6.7 Updates - Released July 20th, 2013 (Supporter)
**** Fixed the timer issues that was occuring with ie10 & ie8.
**** [Feature] SetAppAsDefault.
**** [Feature] TimedWaitForWindow and CloseWindow.
**** Compiled DHTMLx to v3.6.
**** Removed 64bit options as they are auto-enabled.
**** Added {CMD} to the list of functions.
**** Add Win2k to conditions.
**** Fixed a executebefore64bit error.
**** User file written version updated slightly.
**** Fixed a autologoncount error.
**** Fixed a alert sound location error.
**** More info added to the installer log.
**** Removed more old leftover code.
**** Added setfilesystem to the conditions.
**** More fontinstaller improvements.
**** Tons of textual errors fixed.
**** Added {MSI} to the commands for standard msi files.
**** Added alerts to themewizard when exiting.
**** Fixed a couple of resolution errors.
**** Restored "Float" for the tooltips.
**** Tons of minor features improved.
**** Fixed AutoAdminLogin feature.
**** Added HiPerformance Power Scheme for Win7.
**** Redundant code removal.
**** Theme fixes.
**** Expanded wmi functions.
All of the fixes supporters are enjoying:
**** Theme fixes.
v8.6.6 Updates - Released April 8th, 2013 (Supporter)
**** Slight Themewizard changes.
**** More code cleanup and minor fixes.
**** Added function getProductKey.
**** Fixed a dependancies bug.
**** Fixed the download feature in Win7 & Win8.
**** Fixed Edition ID in WinXP.
**** WinXP will now display CD\DVD Info properly.
**** Added function Detect Keyboard Layout.
**** OSLang Improvments.
**** Enabled Drag 'n Drop in configuration tab.
**** Fixed installation order bugs.
**** Fixed timer issues when using IE10.
**** Fixed the runinvalidsignatures issues.
v8.6.5 Updates - Released Jan 19th, 2013 (Supporter)
*** Fontinstaller finally works!
*** Tons of internal code fixes.
v8.6.4 Updates - Released Jan 14th, 2013 (Supporter)
*** Officially added myselfidem to the developers. WELCOME!
*** Diskchanger enhancements.
*** Restored var OSProps, winMgts;.
*** Connectedtointernet is now a visible condition.
*** isdesktoploaded is now a visible condition.
*** TONS of manual internal fixes and corrections.
*** Minor installer.hta cleanup.
*** SystemEnclosureType fix.
*** Added in wmi detection FirewallProductName, AVProduct.
*** Fixed the extra buttons not showing on USB by default.
*** Changed a ton of nobr tags.
*** Lots of minor fixes to the internal .htm files.
Please remember donations are all that keep WPI going....
Thanks Kel, as always
For me the theme wizard bug still present, I set installer bg and progress bar to Win8 and when I click theme wizard again its back to the default black ones (does not remember previous settings)
Aaaa!!! OK, found the culprit...its because I am using the CorporateIT theme that this happens with (the default win7 theme is fine)
I set corp. theme, change installer bg and progress bar, save, reopen theme manager and the installer bg and progress are not remembered (yes they are set, only the settings dialog does not remember)
