Gorki Posted June 10, 2007 Posted June 10, 2007 (edited) Ultra ISO v8.6.3.2052 PEUltraISO is an ISO CD/DVD image file creating/editing/converting tool and a bootable CD/DVD maker , it can directly edit the CD/DVD image file and extract files and folders from it, as well as directly make ISO files from your CD/DVD-ROM or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CD/DVDs. You now have the power to make and edit your own ISO files, and then burn them to CD/DVD for your own needs. UltraISO is in sole possession of the intellectualized ISO document format analyzer, it can process at the present time almost all types of image files, including ISO and BIN, it may even support new image files which are yet to be created. UltraISO can open these image files, directly extract files and folders, edit it and convert other image files to the standard ISO format. UltraISO uses the double window unification user contact interface, you have the choice to only use the quick buttons and/or the mouse Drag & Drops, you can handle any CD/DVD image file easily.MD5: A03227C11A304A69814AEF768B1A7FDDSize: 3.09MBChangelog:15-July-07v0.3- Updated to new version4-July-07v0.2- fixed some conflicts with registry information strings.10-June-07v0.1- initial releaseNOTE: All those who wont to add their registration info to this addon have to do the following steps (UltraISO MUST be installed):* extract downloaded addon (containing 3 files)* run regedit and find Registration and Username line placed in this location: HKEY_CURRENT_USER\Software\EasyBoot Systems\UltraISO\5.0* open settings.inf file and add this (replace wonted information USERNAME and REGISTRATION with yours)* delete ; in front of both HKCU lines.Here is how it should look like,last two lines. [REGEntries.AddReg]HKCU,"Software\EasyBoot Systems\UltraISO\5.0","UserName",0,"USERNAME"HKCU,"Software\EasyBoot Systems\UltraISO\5.0","Registration",0,"REGISTRATION"* save setting.inf and repack again all 3 files (.cab) as it was before Edited July 15, 2007 by Gorki Quote
Gorki Posted June 10, 2007 Author Posted June 10, 2007 It should be Settings.inf not ini Yep, you are right, corrected my typo mistake, thx Rick Quote
ScOOt3r Posted July 2, 2007 Posted July 2, 2007 thanks Gorki, this actually works with win x64, nice workScOOt3r Quote
Mr.McNally Posted July 4, 2007 Posted July 4, 2007 (edited) Hi Gorki! I finally got to try this out on a real machine yesterday and here is a shot of what I get when I click on the desktop icon. I dont know what the error means, but if I click 'ok' the error box closes and ultraiso starts. I haven't tested the full functionality of the program after the error message, i.e. virtual drive,burning functions.... I did uninstall the program and then reinstalled it using a fresh copy that I downloaded, but the problem remained. Any ideas or suggestions on what or why this is happening? :welcome: P.S. I wasn't getting this error in VMWare using the same image..?..? Edited July 4, 2007 by Gorki Quote
Gorki Posted July 4, 2007 Author Posted July 4, 2007 (edited) Hi Gorki! I finally got to try this out on a real machine yesterday and here is a shot of what I get when I click on the desktop icon. I dont know what the error means, but if I click 'ok' the error box closes and ultraiso starts. I haven't tested the full functionality of the program after the error message, i.e. virtual drive,burning functions.... I did uninstall the program and then reinstalled it using a fresh copy that I downloaded, but the problem remained. Any ideas or suggestions on what or why this is happening? :welcome: P.S. I wasn't getting this error in VMWare using the same image..?..?Ok I will check this out Mr.McNally. What else did you add to your win source cd? What did u use for integration? Did you tweak anything else in Nlite if U use it?Edit: I think I located the problem, it should be ok now. version 0.2 is up Take notice at registration info if you have any intettions of registering your program. Cheers P.S sorry Mr.McNally I acidently push edit button instead of quote button. :sweatingbullets: Edited July 4, 2007 by Gorki Quote
Mr.McNally Posted July 4, 2007 Posted July 4, 2007 Cool! Thanks Gorki! I will give it a shot as soon as I have some time. Funny but I feel sort of bad about pointing out issues I have experienced with the work others have done. Your skills far exceed mine when it comes to this sort of thing. I admire your creativity and determination! Thanks for all of your time and effort! :welcome: Quote
